01-06-2011, 05:46 AM   #1
Debug Mode and Modset File of the 645D
Because we now have an official firmware update of the 645D, some more interesting information about the 645D is available
Could someone, who owns the 645D, please confirm:
1.MODSET-File to enable DEBUG MODE of the 645D is not protected with an 8-digits number (like K-5, K-r)
2. The name of the MODSET file is MODSET.487
3. Commands like "OPEN_DEBUG_MENU" are supported.
01-06-2011, 08:06 AM   #2
Tim Wilson's Avatar
Would love to try, but I don't have any firmware-diving experience so not sure how to answer those questions. The download (OS X version) extracts to a README and a single binary: FWDC207B.BIN, which if opened in an ascii text editor reveals jibberish, of course. Not sure where to go from here.
Tim Wilson
Chicago
01-07-2011, 03:10 PM   #3
Tim, you have to decrypt the firmware first, if you want to look into it.
You can use frmcrypt.exe from pentax-hack.info
Next step would be to disassemble it, and search for the strings.
But thats what others allready did for us
Somone with a 645D has to figure out that it works.
That is not a big thing, just to create a textfile, rename it to MODSET.487, and write a harmless command like [OPEN_DEBUG_MENU] in it.
If you see the debug menu, it was sucessfull, and the camera remains unchanged.
01-08-2011, 08:26 AM   #4
Tim Wilson's Avatar
Got it. Bear with me, I'm new to this.
Doesn't seem to be working. I tried every button while turning the camera on. Tried both card slots.
Anything different I should try?
Tim Wilson
Chicago
03-21-2011, 02:06 PM   #5
Antanico's Avatar
Hi Tim,
I do not have the 645D but I have the file that you can just copy in the memory card.
Then try it leaving the door card open.
If you need the file let me know where to send it in private message.
Regards,
Ant
Italy
10-03-2014, 06:35 AM   #6
on frmcrypt.exe is there a method to use this like cipher!!!
10-12-2014, 08:12 PM   #7
every one says use frmcrypt .exe, ok its command line, but has anyone used it, if so what are the switches. pls see attached pic, it is a win32 programme, thus i pasted frmcrypt in sys32 where cipher (mircosoft en/decryption programme) is located. but then cipher needs switches to run
see cipher usage possibilities Use cipher.exe for command line encryption - TechRepublic
but then hoe to use frmcrypt after installing, see installed screnshot. My question is who has used frmcrypt https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/250555-resurrect...acking-24.html
645d, camera, debug, debug mode, medium format, mode, modset
k-7 debug mode - how to enter Nass Pentax DSLR Discussion 17 01-17-2015 04:56 PM
Pentax k-5 Debug mode eigelb Pentax K-5 38 06-09-2014 01:58 AM
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
Debug mode on K-x. ilya80 Pentax DSLR Discussion 2 11-04-2009 05:12 AM
K10D debug mode and 35 Limited macro treebeard Pentax DSLR Discussion 10 10-21-2009 08:47 PM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
