02-03-2011, 01:09 AM   #1
Pentax 645D lenses
Hi,
I am thinking of investing in a 645D given that I have a host of 67 lenses from 45mm to 300mm.
Firstly what would be the 35mm equivalent of using a 67 lens on a 645D?
What other lenses would you recommend mainly for landscape
photography using the 645D?
Thanks!
02-03-2011, 05:00 AM   #2
Welcome to the forum.
I believe that 67 lens are the same as the 645 lens in calculating their 35 mm equivalent, which is 2/3. For example your 67 format 45 mm lens would be 30 mm in a 35 mm format. The smaller 645D sensor results in a 1.25 crop factor, so your lens would be about a 38 mm equivalent.
Hope this helps,
Jim
02-03-2011, 06:37 AM   #3
Hartblei 45mm Tilt-Shift Super Rotator is excellent quality lens or 645D.
02-03-2011, 08:41 AM   #4
leping's Avatar
QuoteOriginally posted by shrinba Quote
Hi,
Thanks!
Equivalent focus length depending on the format you print. If you can afford the camera, digLloyd's on going (now 34 pages) 645D camera and (645+67) lens review + test on his paid DAP is a good start.
02-04-2011, 10:28 AM   #5
The only thing that matters is focal length. I will give you an easy way of visualizing field of view regardless of format. First find the normal focal length for the format--that is simply the diagonal of the format. In the case of the 645d, that is 55mm. Then just figure out the change in angular magnification but dividing the new focal length by that. A 110mm lens will have 2x magnification. A 300mm lens will have about 6x. A 27mm about 0.5x.
So if you like using an 85mm on 35mm (2x as 35mm normal is 43mm), then you will like 110mm on a 645d, 300mm on a 4x5, 40mm on a micro four thirds, 60mm on an APS-C.
I really think we should get rid of the crop factor. (Besides, real photographers didn't always use 35mm. )
02-04-2011, 05:48 PM   #6
I wish you could get your hands on a 645D and test this lens out and post dngs for all of us to look at, not a cheap lens at 2600.00
Steven
QuoteOriginally posted by hartblei Quote
08-26-2011, 03:32 PM   #7
spacevoid8's Avatar
where we can see sample images?
645d, camera, lenses, medium format, pentax 645d
Pentax 645D and LS lenses Ramn Pentax Medium Format 25 05-31-2014 09:29 AM
Manual Focus Lenses on 645D kuau Pentax Medium Format 18 03-21-2013 01:54 PM
645D and FA645 lenses Pl Jensen Pentax Medium Format 17 03-21-2011 03:20 PM
New lenses for 645D igorphoto Pentax Medium Format 14 06-06-2010 05:08 PM
Is 645D compatible with Pentax 6x7 lenses ? Samsungian Pentax Medium Format 41 04-21-2010 12:53 PM
All times are GMT -7. The time now is 10:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
