02-05-2011, 08:49 AM   #31
Ratmagiclady's Avatar
Waist level finder and manual focus? or maybe EVF only?
(I think the idea of cutting out the weather sealing is pretty ludicrous: even a down-spec'ed 645D would still be too expensive a camera not to weatherseal or to start cutting out too many things that are just electronics. )
02-05-2011, 08:49 AM   #32
ogl
Banned
I think if low-end 645D will be real, it could cost approx. ~7000 USD (with 31 MP sensor).
Compare with - H4D-31 ~ 13000 USD.
645D ~ 10 000 USD
H4D-40 ~ 18 000 USD
And I think we could see 645D 50 MP version later .
02-05-2011, 08:53 AM   #33
ogl
Banned
QuoteOriginally posted by zackspeed Quote
Maybe 3 Body in complete?
One lower with Poliycarbonate body,no seals and 22 Megapixel.
One higher class is also possible.
And that the actually body will be alone the next time,is to exclude
Best regards,Andy
Weather seals costs very low.
DFA55 and DFA25 are WR. No need to remove WR from camera.
But...yes. Poliycarbonate body, 31 MP or less, worse VF, cheaper LCD, 1 AF point e.t.c
02-05-2011, 09:44 AM   #34
If I was paying for a camera I'd want a top-of-the-line beast, not something cut down with horrors like a plastic body (saves very little I suspect - indeed may put up the price as it would be a different moudling) or an EVF. One of the main costs of the 645D I suspect is in it's restricted production run - you have all the development costs but far fewer bodies to bear it. Once you start fiddling with the design you are putting the development costs up, are you going to well enough extra bodies to make it worth-while? Probably not with something at this price level.
02-05-2011, 10:00 AM   #35
Kenn100D's Avatar
QuoteOriginally posted by blende8 Quote
You cannot use FF lenses on a MF body, except you change the register distance. And that makes no sense.
Principle is like Lumix LX3 for the sensor side. The rest will be dependent on the converter.
02-05-2011, 10:06 AM   #36
blende8's Avatar
QuoteOriginally posted by Kenn100D Quote
Sorry, I don't understand.
02-05-2011, 10:27 AM   #37
Banned
There is a question on dpreview Question: the Pentax 645D; any sales figures known? so any input on that topic?
@ogl I think that it is very easy to produce the 50mp 645D with the KAF-50100 sensor wich runs on the same platform as the KAF-40000. You coult just put it in I guess. Only it needs a faster CPU then the current PRIME II.
02-05-2011, 11:04 AM   #38
gazonk's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
Indeed, the specs say it has the same pinout. It's slightly larger, so the 55mm lens, which is a "perfect normal" right now (equivalent to 43mm on 35mm) would be a moderate WA lens (equivalent to 38mm on 35mm).
02-05-2011, 11:06 AM   #39
ogl
Banned
from April of 2010 till February 2011 - ~ 6 000 units, I guess...
02-05-2011, 11:11 AM   #40
ogl
Banned
QuoteOriginally posted by gazonk Quote
Maybe Kodak will make new 44*33 sensor with 60 MP.
02-05-2011, 11:22 AM   #41
The 645D is already "Cut Down" if you consider the lack of lenses available.
02-05-2011, 11:25 AM   #42
Banned
QuoteOriginally posted by ogl Quote
from April of 2010 till February 2011 - ~ 10 000 units, I guess...
really that much???? It was stated at start somewhere (if that was true?) that there was contract for 300-500 sensors a month. That would make it a year production of 3600-6000. Did that changed due to larger demand?
02-05-2011, 11:28 AM   #43
ogl
Banned
QuoteOriginally posted by ronhendriks1966 Quote
~ 6000
02-05-2011, 11:46 AM   #44
QuoteOriginally posted by cats_five Quote
Plastic bodies are far cheaper. The restricted production run is a reflection of the market. Dropping the price does not necessarily translate into an increase in sales. The market for this camera is limited, even if the price dropped 20%. I think Pentax believes/hopes this model will be in production for longer than a consumer camera, which will help them recoup their cost and turn a profit. And the sales will help them decide how much money they are going to put in to design lenses for it--the old FA lenses will probably not return. Pentax/Hoya is not the company that brought us the 645 and 67. In a way, they are starting from scratch again.
The good news is it looks like a success.
02-05-2011, 12:08 PM   #45
Banned
QuoteOriginally posted by Yamanobori Quote
Please stop spreading nonsens when you only make a guess instead of doing research.
The FA lens serie is for sale at the time. I don't believe old stock, but new production. Some of them where already in production in Vietnam for some years. I have a 75mm lens dat is assembled in Vietnam.
645d, camera, medium format
Stocking stuffer for the "masses" ;) jeffkrol General Talk 0 12-19-2010 09:06 AM
645d!!! insulinguy Pentax News and Rumors 1 10-12-2010 07:36 AM
645D is here ... frank Pentax News and Rumors 810 03-24-2010 10:14 AM
Using the 645D... HawaiianOnline Pentax Medium Format 13 03-23-2010 07:17 PM
Cheap lighting for the masses! codiac2600 Post Your Photos! 17 02-23-2008 05:50 PM
All times are GMT -7. The time now is 05:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
