Originally posted by VoltMan I wouldn't dare try this on an Arca Swiss Cube for example.
I have used the cube with my rather substantial 8X10 view camera and it does passably well, though at certain angles the cube does show signs of instability, but those are rather extreme angles that are unlikely to be used in common usage. I chose the Manfrotto 405 because it has no exposed gears like the cube does, and therefore is more mechanically robust in less than perfect weather and less likely to seize up in sandy conditions.
The 405 handles my 8X10 with aplomb even when it is fully loaded with a short telephoto lens of 830mm. I have used the 405 with my pentax 67 with my M*800mm f/6.7 ED [IF], and as a test I used it with mirror lock up...I set a glass of water on the top of the 67 and when I fired the shutter I observed next to no perturbation on the surface of the water, which shows outstanding performance. Very few tripod heads pass the glass of water test, my B55 from RRS which is my ball head of choice handles this test quite well.
