02-28-2011, 02:53 PM   #1
Flash with studio flash and 67II
I shot a few still life's with my Intrex 300 studio flash, set a a low level, and my camera fired the flash twice and now refuses to fire it any more.
Have I committed circuit frying? The manual does not deal with this issue, talks only about Pentax flashes.
03-01-2011, 07:33 AM   #2
When I google search for Intrex 300 flash, I find nothing but your post. The 67II should work with any standard studio strobe.
03-01-2011, 07:47 AM   #3
Wheatfield's Avatar
If you are using a PC cable, check the cable (as in replace the cable). They are notoriously unreliable unless you spend real money on them.
03-01-2011, 09:36 AM   #4
Yes, what Wheatfield said is probably the case. Now that I recall, I've had poor fitting PC cables not fire at all. I've had to flare out the end to get a better fit as well as press my thumb on them while shooting on occasion.
03-01-2011, 10:43 AM   #5
Flash and 67II
You guys are spot on! Wheatfield said it- when I hold the cord tight to the body of the camera, it fires all the time. Hooray and thanks.
BTW, what are the two small contacts adjacent to the pc receptacle for? I could not figure that out, and the manual does not address that.
03-01-2011, 11:04 AM   #6
Wheatfield's Avatar
QuoteOriginally posted by Herb Quote
http://www.pentax.jp/english/support/man-pdf/67II.pdf
Page 59.
Dedicated flash connection.
I think the camera came with a rubber cover on it originally.
03-01-2011, 11:40 PM   #7
Digitalis's Avatar
I dispense with those cables entirely and use a wireless transmitter system I personally use the Elinchrom skyport system but there are many others out there at varying price points that would suit your needs.
03-02-2011, 10:09 AM   #8
Even with a wireless system you have to connect the transmitter to the camera with some kind of cord to the camera's 4P or 5P-sync terminal. And could still have the loose connection. Not sure about the dedicated flash contacts the 67II has. Maybe the hot shoe adapter would work better for that.
03-02-2011, 05:13 PM   #9
Digitalis's Avatar
or you can use the pc-synch port on a leaf shutter lens like I do.
03-04-2011, 03:31 AM   #10
fs999's Avatar
lol...
03-05-2011, 04:23 AM   #11
Flash with 67II
I got on the Pentax web site and asked them. They recommended the hot shoe adapter and of course buying one of their flashes.
Now, do ALL the 67II's have TTL? Before i go off buying another flash.
camera, flash, medium format, studio, studio flash
K7 and studio flash 2megs Troubleshooting and Beginner Help 1 12-31-2010 09:29 AM
studio flash incompatibility? keithross39 Pentax DSLR Discussion 4 10-08-2010 05:41 AM
k20d studio flash fred412 Pentax DSLR Discussion 1 11-22-2009 07:23 PM
K200D and studio flash c a sugg Troubleshooting and Beginner Help 7 07-03-2009 11:58 AM
67II -- which sync cord for TTL off-camera flash? Dick Sanders Pentax Medium Format 2 05-29-2009 07:57 PM
All times are GMT -7. The time now is 08:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
