03-01-2011, 01:03 PM   #1
Help! Pentax 67 blank frames/shutter issue
Hi,
I recently acquired a new (to me, anyway) 67 body from eBay, and I'm having an issue where I get a number of totally blank frames on a roll of film.
On the first roll, there was only one such blank frame, so I attributed it to user error (exposing with the lens cap on, etc). But on the second roll, there were four totally blank frames, and one partially blank frame! I shot that one in the span of about half an hour, and I can say with confidence that I didn't take photos of the lens cap four and a half times.
The cause that immediately comes to mind is the 2nd shutter being out of sync with the first shutter.
Before I send this one off to Eric for a CLA, has anybody had a similar issue/know any possible fixes?
03-02-2011, 05:19 AM   #2
Try a fresh battery; I've had missed frames caused by a weak battery
03-02-2011, 09:53 AM   #3
QuoteOriginally posted by kkado Quote
Hi,
Are you using a leaf shutter lens? It looks like there is only one large fabric shutter.
03-02-2011, 05:35 PM   #4
I haven't been using a leaf shutter lens, just the 105/2.4. What I mean is, I think the second shutter curtain is sticking to the first shutter curtain.
The thing that puzzles me is that I'm using a brand new PX28L! I will do more testing tonight to figure out if cold temperatures are causing the shutter/battery to fail.
03-02-2011, 06:42 PM   #5
Are you familiar with the process setting the camera to fire without film in it? Set that way, you maybe could remove the lens, lock up the mirror, put your thumb in place to keep the mirror up and fire the camera watching the shutter. It all happens so fast though.
My 67 only has one shutter curtain. A large fabric shutter that opens left to right when viewed with the back open. So I'm a little confused when you say the second shutter.
03-02-2011, 07:53 PM   #6
Yes, I've tried dry firing the camera to observe the shutter, and I think I've isolated the cause. It seems to happen when the camera body is cold (I stuck it in the refrigerator, so about 35-40F). In this case, the 1/1000th and 1/500th speeds do not work consistently. It does not matter whether the battery is warm or cold. Here's a screengrab from video I took of the shutter, when it's working at 1/1000th:
When it isn't working, you cannot anything through the shutter.
The shutter does not really have a diagonal opening, it is just an artifact of the video camera's "rolling shutter." Most focal plane shutters are designed with 2 curtains; with faster speeds, the second curtain follows the first curtain so that only a small slit of light exposes the image:
03-02-2011, 08:04 PM   #7
Interesting. Are you generically saying 67 or do you mean the 67 generation of the camera given there are a non-MLU 6x7, 6x7, 67 and 67II versions of the camera?
camera, cap, frame, frames, half, issue, lens, medium format, roll, shutter
K10D shutter issue - easy to fix? Christine Tham Pentax DSLR Discussion 18 02-12-2011 07:16 PM
Pentax K-X Shutter or Sensor Issue Due to Moisture Adam B Pentax DSLR Discussion 4 11-10-2010 12:19 PM
K10D corrupted/blank images issue Mart Pentax DSLR Discussion 6 10-31-2009 12:42 PM
ME super Shutter issue, help winglik Pentax Film SLR Discussion 0 03-01-2009 01:38 PM
All times are GMT -7. The time now is 06:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
