Originally posted by tuco Is the ambient light in your studio so strong that you need a higher snyc?
Is the Bowens 500 a Gemini 500c/500r or Pro?
I don't have my own studio and the ambient light in the studios I hire varies quite a lot.
I've seen some very cool stuff done outdoors using high sync speeds and fast shutters to control the ambient daylight and flash/strobe lighting as the main key lights.
I certainly don't "
need" a faster sync (if I did I wouldn't ahve forked out $10K+ for the 645D!!), would just be nice to have the option to play around a bit more and do that easily.
Checked the specs of the 500 Gemini and the flash duration is 1/925 - so shouldn't be an issue using those lights and going faster than the 1/250th I've used so far with my cheat.
