Opens the link, hoping, prayig for something that looks like tethering .........
- When processing Noise Reduction after long exposure, remaining time is displayed on LCD panel
- When mode dial is set to “X”, Flash X-Sync Speed can be set by custom function menu.
- When connecting to a computer via the USB cable, recognized Disk name is changed from [Removable Disk] to [645D].
- If format SD memory card, volume label will be [645D].
- After mirror lock-up, extended standby time (until mirror automatically return to original position) from approximate 1 minute to 5 minutes
If Auto Power Off setting is shorter than 5 minutes, Auto Power Off setting has priority.
Bugger
no tethering.
If custom setting the X-sync speed means setting it higher than 1/125th that'll be cool - will have to have a play with this tonight.
Thanks for the heads-up.
