03-13-2011, 09:54 AM   #1
Sticking Mirror
Just received an eBay purchased 6X7 and am sacrificing a roll of film to check operation. After installing the battery, I found that the mirror sticks with each operation. If I remove the battery and give the body a tap, then the mirror releases and returns to the rest position.
The prism fits loose so I have ordered a seal kit which comes with a mirror damper and is supposed to have installation instructions. This will be my first attempt at camera repair/maint. , anyone have tips to offer?
Thanks,
Tom
03-13-2011, 12:08 PM   #2
Does the mirror come down when you press the shutter/mirror reset button?. You can operate the camera without film in it, btw, as noted in the instructions in that link.
03-13-2011, 01:01 PM   #3
The mirror will not come down when I push the reset button.
Thanks for the pdf file, it is a tremendous improvement over the manual I downloaded from the Pentax Imaging site which looks like the mimeographed stuff we used to get in school back in the 60's! I could not read and did not know I could move the frame counter because the image was so bad.
03-14-2011, 11:27 AM   #4
What you describe is pretty common in bodies that have had 15,000+ frames thru them. My original 6x7 did the same thing and needed to be reworked by Pentax. My newer bodies have yet to act up. Fixing this problem yourself would be difficult unless trained in this area. There is a guy who advertises on ebay that specializes in P67 repair.
battery, camera, medium format, mirror, operation
is my lens sticking menifeeminister Troubleshooting and Beginner Help 6 03-15-2010 06:40 AM
Mirror Sticking KayMan Pentax Film SLR Discussion 5 12-15-2009 10:13 AM
k100d shutter sticking cathynwv Pentax DSLR Discussion 1 10-02-2009 08:29 PM
Sticking with the birds dws1117 Post Your Photos! 2 04-21-2008 05:57 PM
what are the signs your shutter is sticking? slip Pentax DSLR Discussion 7 01-30-2007 06:24 AM
All times are GMT -7. The time now is 09:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
