05-16-2011, 09:31 PM   #16
"So you meter an out of focus, evenly light white board to place that value 4 stop below middle gray at box speed, shoot, adjust subsequent exposures 1/2 (or 1/3 stops if you have lenses capable of that) above and below the initial metering. Measure the density of each frame and the closest one to 0.1 above fb+f will be your film speed which you determine by the number of stops or fractions thereof from the metered shot."
I will run a roll as you suggested starting at 4 stops below. So that I have it perfectly clear: simply shoot an evenly lit unpatterned whiteboard. Can the lab measure the density of each frame of the film base and fog ("fb+f")? I should choose the frame (and corresponding underexposure factor) which is .01 above the fb+f. Do I have it right?
Presently I am guessing the correction i.e. shooting ISO 50 Velvia at ISO 32.
Thanks for the help.
05-16-2011, 10:16 PM   #17
QuoteOriginally posted by rmarkus Quote
My instructions were course and off memory I used for BW film. I'd read a procedure that you should be able to find on the web. The matt board should be more middle gray for slower films. It may need to be darker for faster films to give you a better range of apertures. I used a one-degree spot meter which I meter with normally. You can also use and change ISO settings if you're using your camera's meter instead of the aperture. You should get finer control that way.
camera, medium format
K-r underexposure vs. k-7/k-5 jackero27 Pentax K-r 17 05-17-2011 05:13 PM
Underexposure? spidey Pentax K-r 8 03-27-2011 01:10 PM
Another Underexposure...please help PentaxKX-2011 Troubleshooting and Beginner Help 16 01-19-2011 12:27 PM
Pentax K7 and underexposure ulrich Pentax DSLR Discussion 13 05-13-2010 03:15 PM
MZ-7 and underexposure photolady95 Pentax Film SLR Discussion 89 07-09-2009 09:44 AM
All times are GMT -7. The time now is 09:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
