05-24-2011, 02:31 PM   #1
645 issue with picture corners
When I use a 45mm on my 645, I get black corners on some of the frames (aperture does not matter). I have gotten the same issue on some B&W that I developed, and thought maybe I had loaded a portion of the film onto the reel incorrectly, but the below shot was processed at a local camera store. Anyone have any ideas what's going on??
05-24-2011, 02:58 PM   #2
pbo
pbo's Avatar
Do you use a round hood by any chance? If it's too deep, it might be that you are getting vignetting with hood on and no vignetting with hood off.
05-24-2011, 03:35 PM   #3
QuoteOriginally posted by pbo Quote
I had not considered that, but it makes sense. I will shoot a roll without the
hood. Thanks!
05-24-2011, 05:15 PM   #4
QuoteOriginally posted by Bogie Quote
hood. Thanks!
You should be able to spot it in the viewfinder.
05-24-2011, 06:44 PM   #5
Hood or the filter(s).
05-24-2011, 07:43 PM   #6
D W
QuoteOriginally posted by Yamanobori Quote
Maybe not, the viewfinder is not 100%.
05-25-2011, 07:35 AM   #7
pbo
pbo's Avatar
QuoteOriginally posted by Thomas Quote
Oh yeah, filters also would do that. Maybe if you're using too many or if filters are too thick, that would happen.
05-25-2011, 11:52 AM   #8
QuoteOriginally posted by D W Quote
Even with 100% view it may not be noticeable. Two cases in point. My Hasseblad 500 C/M and Distagon CB T* 60mm. I put the 80mm lens hood on and looked through the view finder. Looked okay. The shots ended up with lens hood vignetting. Same with my Distagon CF T* FLE 50mm with two filters. I didn't see any noticeable vignetting. Maybe looking at a pure white area would have helped.
05-26-2011, 04:23 AM   #9
Thanks to all for the thoughts and suggestions! I had the hood screwed onto the filter and am sure this is the issue. Thank goodness it is a simple fix!
camera, corners, issue, medium format
Dark corners, Da 18-135 ED DC normhead Troubleshooting and Beginner Help 6 01-31-2011 06:10 PM
645 Issue Halco Pentax Medium Format 4 03-18-2010 08:18 PM
DA*16-50: are the corners that bad... tigrebleu Pentax SLR Lens Discussion 12 09-03-2009 06:01 AM
AF adjustment problem. Different corners, different focus results. Saul Pentax SLR Lens Discussion 3 03-22-2009 06:50 PM
Picture of the new 645 Digital TankSlapper Pentax DSLR Discussion 8 02-22-2007 01:11 PM
All times are GMT -7. The time now is 02:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
