05-30-2011, 02:28 PM   #16
gkb
There is a lens profile in ACR that corrects the 55mm distortion.
Yes I know it and do use the ACR correction. But for precision work it does take also away detail information, a macro lens is always the better solution.
05-30-2011, 02:36 PM   #17
feverbeaver's Avatar
How about the 67 55mm 4.0 (late version)?
05-30-2011, 05:17 PM   #18
Digitalis's Avatar
QuoteOriginally posted by gkb Quote
the D-FA 55mm f/2.8 is fine to shoot wide open, nice and sharp. But has bad distortion. Now I tested the 2.8 75 A version and found it pretty good regaring distortion (not straight like the macro 120 though), and CA is ok too. Sharpness is also nice at f11. Best would be to have such a Leica Elmar 3,5/65 somewhere already adapted and make a comparison test...
the Leica lens probably won't be much better than the Pentax - it's a very old Lens design. Just because it has the Leica name attached to it doesn't necessarily mean it is going to be perfect. The Leica TRi-Elmar 28-35-50mm f/4 ASPH has some pretty bad distortion, especially at the wide end - and that is a modern lens design.
A pentax 67 lens could possibly be a better choice - since you would be using a small portion of it's large image circle - distortion would be reduced, resolution across the imaging field would also be pretty decent...If you choose to go down this path I would recommend the Pentax 67 55mm f/4 - which is to this present day, sharper than the Carl Zeiss equivalent.
05-30-2011, 07:28 PM   #19
D W
i use a cheapie plastic bellow made for 35mm fixed onto a cut up body cap that I use with the 80mm. Dremel and crazy glue are my friends. 105mm works better but you need distance which is not always possible at galleries or museums.
05-31-2011, 01:44 PM   #20
gkb
good idea with the 35mm bellow and the crazy clue. I absolute love those solutions and will go after it.
Like Digitalis wrote and Sergio approved, the Leica Visoflex 65 has more distortion than the old Pentax 75mm A. So skip the Visoflex...
Pentax 67 55mm f/4 sounds also interesting, thank you for the recommendation.
06-04-2011, 05:24 PM   #21
How about an adapter and a Planar 100/3.5? Distortion is nil..
06-04-2011, 06:35 PM   #22
Digitalis's Avatar
QuoteOriginally posted by Bob YILDIRAN Quote
but it is still a 100mm lens. the OP is looking form something wider.
camera, lens, macro, macro lens, medium format, range
Budget mid range zoom ~ 28-105mm tim_kayak Pentax SLR Lens Discussion 12 03-20-2011 03:08 PM
Rambling mid-range zoom comments pacerr Pentax SLR Lens Discussion 2 10-17-2010 08:25 PM
the best mid range tele? axl Pentax SLR Lens Discussion 1 07-13-2010 05:39 AM
645D dynamic range Pål Jensen Pentax Medium Format 9 04-30-2010 09:00 AM
mid range tele options which is best? 300xcw Pentax SLR Lens Discussion 3 02-20-2008 12:17 AM
All times are GMT -7. The time now is 02:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
