07-09-2011, 12:28 PM   #1
Firmware update problems
I am trying to update the firmware of my 645D from 1.02 to 1.10 and it's not working. I've copied the BIN file to my SD card 2 different times as well as numerous reboots with the menu button pressed. All I get is a display of my curreent firmware version for a few seconds and then it goes on to the menu display.
My only thought is that the battery is only about 60% charged. Is it possible that the camera needs to see close to 100% before it will proceed with the update?
Anyone else having this problem?
Thanks,
Peter
07-09-2011, 01:39 PM   #2
Follow up: still no success after a fully charged battery!
I might need to talk to someone at Pentax about this problem.
07-10-2011, 12:23 AM   #3
Have you copied the file into the root directory?
-Linus-
07-10-2011, 09:46 AM   #4
Oh yes and formatted the card beforehand.
07-11-2011, 08:17 AM   #5
Not a problem at all! After reading the instructions a 4th time I saw that the SD card containing the BIN file must be inserted in slot #2. I kept trying to load it from slot #1.
Thanks to all for trying to help.
Peter
07-12-2011, 10:56 AM   #6
Where did you find version 1.10? I only see 1.02 on pentax usa site
07-12-2011, 11:28 AM   #7
QuoteOriginally posted by Shuttershane Quote
1.10 is on the Pentax site. The update makes the new GPS compatible with the camera.
http://www.pentax.jp/english/support/digital/645d_s.html
07-12-2011, 12:05 PM   #8
Isn't it that when you turn on the camera with the SD card (with .bin) there, that you should NOT be pressing the menu button?
07-12-2011, 12:33 PM   #9
"you should NOT be pressing the menu button?"
The instructions tell you to copy the BIN file into the root directory of your SD card. Then you load the card into slot #2. Then you turn on the camera with the menu button pressed. It will instantly start to load the BIN file.
It worked fine for me.
07-12-2011, 12:47 PM   #10
ok my mistake. i upped my fw to the one before 1.10 since i have no gps
07-12-2011, 05:57 PM   #11
Great! As for me, I've been wantin' a GPS attachment on my camera since 2005! This is a godsend for me.
camera, display, firmware, firmware update, medium format, menu, update
KX FIRMWARE UPDATE ANVILHEAD911 Pentax DSLR Discussion 9 12-12-2014 08:41 AM
K20D v1.01 firmware update compatibility dosdan Digital Processing, Software, and Printing 3 11-15-2008 01:17 PM
firmware 1.3 problems reynb Pentax DSLR Discussion 4 01-19-2008 10:14 PM
Sigma EF-500 DG ST Flash Firmware Update For Pentax K10D stewart_photo Flashes, Lighting, and Studio 3 08-10-2007 07:06 PM
Firmware Update Questions switch79 Pentax DSLR Discussion 8 05-03-2007 04:33 AM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
