09-16-2011, 02:12 AM   #1
spacevoid8's Avatar
uncompromising alternative to pentax 35mm manual lens
of course in terms of resolution... your suggestions..
09-16-2011, 02:42 AM   #2
samyang 35mm f/1.4
09-16-2011, 03:20 AM   #3
Digitalis's Avatar
You could modify a Contax 645 Zeiss distagon 35mm f/3.5 lens - that might offer superior image quality to the A series 35mm f/3.5 - though knowing Pentax the A series lens would probably be a refinement of the Zeiss lens design - so it is possible there will not be much improvement in IQ.
Contax 645 lenses are still quite expensive these days, older Hasselblad V series lenses could also be adapted but for 6X6 format 38mm is the widest lens hasselblad produced that isn't a fisheye
QuoteOriginally posted by adpo Quote
samyang 35mm f/1.4
The samyang lens isn't compatible with the Pentax 645D
09-16-2011, 05:29 AM   #4
CDW
Assuming you get a good copy, the manual focus 645 35mm lens is close to as good as it gets, especially in the F8-11 range.
09-16-2011, 05:31 AM   #5
spacevoid8's Avatar
QuoteOriginally posted by CDW Quote
i`d say F11-F13!!
09-16-2011, 05:32 AM   #6
aurele's Avatar
he probably didn't realize he was reading a MF subject ...
09-16-2011, 09:47 AM   #7
QuoteOriginally posted by aurele Quote
And the OP just assumed everyone understood he was talking about a 645 format with that subtle clue of a manual lens and reputation. The Pentax 6x7 also has a 35mm lens and is a medium format camera.
09-16-2011, 10:37 AM   #8
this is why i shouldnt post at 3 in the morning -.- sorry about that!
09-16-2011, 05:09 PM   #9
Digitalis's Avatar
...especially without coffee...
09-19-2011, 02:16 PM   #10
The Hasselblad 38mm Biogon! is a fixed lens on the Hasselblad SWC body. It is an "original SW lens" - no retrofocus ! - with a superb quality, but you canīt adapt it If you want to adapt a Hassy V lens - take the 40mm Distagon FLE, the 30mm F-Distagon is a fisheye (F=fisheye).
09-19-2011, 05:26 PM   #11
Digitalis's Avatar
QuoteOriginally posted by veraikon Quote
nice to see someone who knows their cameras, no the 38mm Biogon is not adaptable. The registration distance differential between Pentax 645 and Hasselblad V is 70.87mm Vs 74.9mm - which means getting infinity focus could be a bit tricky. The flange on the Contax 645 is exactly 64mm - so that would be the more manageable option when it comes to adapting lenses.
09-19-2011, 05:46 PM   #12
You lost me. How can you adapt a lens with a flange distance of 64mm and retain infinity focus with a Pentax body with a flange distance of 70.87mm? And why would the Hasselblad lens with a longer flange distance be harder? Especially since there are Pentax 645 to Hasselblad adapters available.
09-19-2011, 08:08 PM   #13
Digitalis's Avatar
Sometimes a lens with a shorter flange focus distance can be easier to adapt than a longer one - adapting a lens also depends on the design of the lens itself - and if you have ever worked on a Contax 645 lens you will know what i'm talking about - the helicoids on Contax 645 lenses are longer than they are supposed to be. Which means you can bring the optics further forward to the infinity focus point on a pentax 645 - however on a Hasselblad V series lens you can't - the optics to move back far enough to get infinity focus on a Pentax 645
camera, medium format, pentax 35mm
10x big stopper filter for 35mm F3.5 manual lens spacevoid8 Pentax Medium Format 8 08-19-2011 12:46 PM
Shopping advice for fast manual ~35mm lens bkhl Pentax SLR Lens Discussion 4 08-10-2010 09:00 AM
mc PENTAX 35mm f3.5 on k10D how to use manual lens Asgaroth Troubleshooting and Beginner Help 2 05-28-2009 01:22 PM
pentax p-fa 35mm f/2 alternative lens hood architorture Pentax SLR Lens Discussion 0 12-28-2008 01:55 AM
All times are GMT -7. The time now is 06:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
