09-29-2011, 03:09 AM   #1
55mm soft
Hi All ,
Just received a 67 55mm from KEH and have found it to be soft up to f8 and after that good but not great .
My 645 75mm and 120 Macro are both noticeably better on 645D.
The base opinion is 55mm is one of the sharpest lens from Pentax , should I box it up and return it ?
Thanks
Jon
09-29-2011, 06:41 AM   #2
My copy of the 55mm A is a little soft wide open but sharpens up noticeably by f4 and seems definitely better than the copy tested by Lloyd Chambers in his blog diglloyd. It sits between my 35 and 75 lenses, both pin-sharp, without in any way seeming like a poor relation, and I use it without hesitation in any situation where that focal length is called for.
09-29-2011, 08:32 AM   #3
QuoteOriginally posted by dgpaterson2000 Quote
My copy of the 55mm A is a little soft wide open but sharpens up noticeably by f4...
f4 is wide open for a 67 55mm.
09-29-2011, 10:29 AM   #4
Send it back. if it's the latest 55/4 ( SMC Pentax 67) it should be great. Don't settle for a sub-par copy. There is sample variation between lenses. It took me three tries to get a 45/4 that had decent corner performance.
09-29-2011, 01:28 PM   #5
Sorry - didn't notice the original post was about the 67.
09-29-2011, 05:13 PM   #6
Banned
I have the F3.5 55mm with eight Pentax 100mm filters.
09-29-2011, 07:39 PM   #7
QuoteOriginally posted by jogiba Quote
Yes, but that is not a 67 55mm noting the difference between a SMC 67, SMC 6x7 and S-M-C 6x7 generation lenses.
10-01-2011, 03:15 AM   #8
yeah , thanks everyone , its the latest 67 .
Will return and hopefully buy one from here if Arcasia /Alan still has it for sale .
10-05-2011, 06:02 PM   #9
jlandecker's Avatar
FWIW, the latest version of the 55 has a "floating element". When you turn the focus ring, the front of the lens moves at a different rate than the rear. It seems that the rear focusing mechanism often has some fore-aft play in it - I've personally seen 2 copies that had this, and both were cosmetically in very good condition and seemed to perform well optically.
This thread on photo.net describes the same thing. Hold the lens with the rear facing down and push gently on the outer edge of the rear element (not the glass!) to see if it moves up and down.
According to the other threads it seems to be fairly normal, but I'd be curious whether other owners' copies behave like this, and if anyone knows whether this is how the lens is designed to work.
Jim
55mm, camera, medium format
Soft focus on SMC Pentax-DA 18-55mm F3.5-5.6 AL WR khvatov Pentax SLR Lens Discussion 7 07-29-2010 05:47 AM
For Sale - Sold: M42 Lenses. Pentax Taks 35mm, 135mm, 55mm, Fujinon 55mm Peter Zack Sold Items 5 03-04-2010 05:24 PM
For Sale - Sold: Spotmatic SP-F w/ SMC 55mm/1.8, K2, MESuper, NIB MESuper Soft Case monochrome Sold Items 9 12-05-2009 11:15 AM
The Soft Place: Post Your Soft Focus Images jeffkpotter Post Your Photos! 22 04-23-2009 09:04 PM
Soft Lens Case for the DA 18-55mm PentaxKangaroo Pentax Camera and Field Accessories 4 01-18-2008 03:56 AM
All times are GMT -7. The time now is 08:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
