10-17-2011, 09:37 PM   #1
Why won't my lightmeter on my Ashai Pentax 6x7 work?
Hi everybody!
I'm new to this, sorry if this has been already posted but I can't seem to find a solution to this problem.
I currently have a 6x7 with a TTL Pentaprism finder. The light meter in the prism viewfinder never moves, it's always at the very top of +
I've read the manual, the battery light goes on so I'm assuming the battery is fine, I've attached the lens properly yet it still won't work.
Any suggestions?
Thanks!
10-18-2011, 03:22 AM   #2
Giveaway winner!
MysteryOnion's Avatar
How is the condition of the TTL? Are there any dents?
Normally, the needle is at the (-) side. if the tiny spring inside the meter is broken then it could send the needle it opposite direction. If this is the case, then it is missing half of its electrical connection. On the off chance, test the meter with the manual mode active. Flip your lens to the "Manual" or stopdown and see if it works in that mode.
10-21-2011, 09:22 AM   #3
MarieDJ
Guest
The resistor might need changing...I would send it out to Eric to have it checked. I have a P67 and recently I had it serviced by Eric because the meter was being erratic. Of course, the camera had not been serviced in over a decade, so I guess it was bound to happen.
Alternatively, you can use the digital spot meter instead and forget the metered pentaprism. It would make your camera so much lighter and you can use a WLF.
10-21-2011, 09:40 AM   #4
MarieDJ
Guest
BTW, which manual did you read? The P67 manual or the Pentaprism manual?
Just in case, I attached the pentaprism manual
10-21-2011, 05:35 PM   #5
I've read all the manuals but I will follow all your suggestions, thanks guys!
battery, camera, light, medium format
Pentax Medium Format Resources: 645 & 6x7 Cameras and Lenses, 645 & 6x7 Accessories Adam Pentax Medium Format 9 02-12-2017 03:38 AM
Why won't my lightmeter on my Ashai Pentax 6x7 work? Raquel D. Visitors' Center 1 10-18-2011 02:59 AM
50 mm / 1.2 Ashai (sp?) Pentax lens doggydude Pentax SLR Lens Discussion 15 02-19-2011 11:21 AM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
