10-18-2011, 05:39 PM   #1
Pentax 67ii service manual
Does anybody have a copy of Pentax 67ii service manual? The only one I managed to find on the web belongs to older 6x7. Got a strange problem with the shutter, gathering up courage to disassemble the body.
Thanks in advance.
02-18-2012, 09:27 AM   #2
iczek's Avatar
Still need one? I have a copy.
02-18-2012, 04:38 PM   #3
QuoteOriginally posted by iczek Quote
I'd really want one! My metering prism is dead. PM?
02-20-2012, 09:06 AM   #4
what happened to the prism, Makten?
02-20-2012, 10:08 PM   #5
QuoteOriginally posted by phonoline Quote
I don't know if it is the prism, but suddenly an error message ("PErr") appeared in the display and then the camera was stuck. This happened once before, but fixed itself after a while, but not so the last time.
Now I have to isolate the contacts between the prism and the body, and I can only use the camera with manual shutter speeds (full stops) without metering. This seems to be a fairly common problem with no solution.
02-21-2012, 03:08 AM   #6
iczek's Avatar
Makten,
I have the same problem with my camera that I purchased from one of internet B&S list
After checking in local authorized Pentax service I know that my case is called: T100
Main board is failure.
Firstly, you should check the mechanism of the lens that push the aperture needle in the body. Than, check the electronic of the main board.
I do not know what is worst.... bad prism or bad main board
02-21-2012, 10:17 AM   #7
Makten,
Ah! Failure of the aperture mechanism would make a lot of sense, because the problem came when I attached my extension tube, which doesn't have a coupling for the aperture. So maybe something went wrong there. But still, the aperture works fine in manual mode.
02-21-2012, 10:28 AM   #8
iczek's Avatar
QuoteOriginally posted by Makten Quote
My prism also works with manual mode one the lens. I think that your prism is ok as well as mine. The problem could be the mechanic only.
Please, let me know one thing... could you switch the meter mode on prism to multi-matrix and check if you can see the correct icon displayed in viefinder?
In ma case there is a problem with this icon displaying.
03-16-2012, 08:22 AM   #9
EdoNork's Avatar
I'm interested in a copy too.
03-16-2012, 01:13 PM   #10
Me three. If electronic, I'd be happy to host it.
03-21-2012, 04:04 PM   #11
I would really like a copy too, please. I'm a new owner of a Pentax 67ii. Any help would be welcome.
03-23-2012, 05:46 PM   #12
Here it is:
Pentax67iiSM.pdf
03-24-2012, 01:29 AM   #13
iczek, would you shoot me a copy of the repair manual please?
03-24-2012, 12:54 PM   #14
EdoNork's Avatar
Thank you vary much swilf!
09-24-2012, 03:21 AM   #15
hi to all
anyone can reupload the file ? in advance, many thanks
67ii, camera, medium format, pentax, pentax 67ii service, service
Anyone have a K20D Service manual please? JohnX Pentax DSLR Discussion 5 10-05-2011 01:44 AM
ME Super Service Manual pandarocket Film SLRs and Compact Film Cameras 20 03-17-2010 12:32 PM
Pentax digital spotmeter - service manual SquintyEyes Pentax Camera and Field Accessories 5 12-08-2009 04:23 PM
Need service manual for a PZ-1p. Bob 256 Film SLRs and Compact Film Cameras 6 07-17-2008 07:47 AM
All times are GMT -7. The time now is 05:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
