10-30-2011, 11:41 AM   #1
TTL flash for 645.
I'd like to get a flash for the 645. Does it use the same TTL as the new digital SLRs. Can I get one flash for the 645 and a K-r if I get one?
10-30-2011, 02:22 PM   #2
Ole
Ole's Avatar
The 645 uses TTL flash. The new DSLRs use P-TTL flash.
The current Pentax flashes like AF360FGZ and AF540FGZ support both modes and can be used on the 645 as well as on a Pentax DSLR.
Older Pentax flashes do not have P-TTL.
10-30-2011, 03:06 PM   #3
What you need is a TTL flash for the Pentax 645 and 645N cameras. If you have a 645NII you get to use P-TTL.
The K-r only supports P-TTL.
As Ole noted both the AF360FGZ and AF540FGZ support P-TTL and TTL so you could use them on both cameras.
Regards
Chris Stone
10-31-2011, 02:49 PM   #4
drougge's Avatar
The Metz 48 AF-1 (and presumably others of the same generation) supports the old TTL as well.
camera, flash, medium format, ttl, ttl flash
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 46 11-15-2017 10:05 PM
P-TTL flash - is it necessary ? Squier Pentax DSLR Discussion 35 10-27-2010 12:55 PM
Non-P-TTL AF Flash trailrider Pentax DSLR Discussion 5 07-21-2010 06:04 PM
645+AF360+TTL? Swift1 Pentax Medium Format 8 03-09-2010 01:24 PM
All times are GMT -7. The time now is 05:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
