12-02-2011, 06:32 PM   #1
jackinkc's Avatar
645D write speed
I am experiencing slow write times with my 645D. I would like to work this out with the assistance of others.
12-02-2011, 06:55 PM   #2
Do you have a class 10 or higher card? The faster your card, the faster the camera can write.
The processor is pretty slow in general though, so you will have to get used to having to wait a little bit to see the photo after you shoot it
12-03-2011, 02:03 AM   #3
My current cards are 16GB Sandisk Extreme Pro, labeled 45 MB/s.
I don't have exact timings, but it looks like just under 4 seconds in total with these cards. The time between the shutter closing and image stored is divided 50-50 between camera processing and file saving.
How does that align with your write times, jackinkc?
best,
Jostein
12-03-2011, 02:05 AM   #4
It is not "pretty slow in general". It is handling large amounts of data in particular.
12-04-2011, 12:37 PM   #5
Anvh's Avatar
From what i can tell it share almost the same hardware with the K5.
I believe the SD write speed came close to 20 to 25MB/s.
But card speed isn't that important,as far as i know an image would take this route: sensor > RAM > processing > RAM > SD.
So as long as the RAM isn't full SD speed won't limit it.
12-05-2011, 03:43 PM   #6
jackinkc's Avatar
QuoteOriginally posted by alunfoto Quote
best,
Jostein
I am using 32GB, 30 MB/s cards. The write time is about 15 seconds in the studio, with flash, and about 8 seconds with regular exposure. That variation makes no sense to me, but I guess 8 seconds write time is not that bad. I suppose if I went to faster cards all would be OK.
Adam suggested a class 10 card or faster; a limited online search shows class10 to be about 24 MB/s. Unless I am misreading the specs looks like Jostein's 45 and my 30 are both faster than class 10.
Maybe I should shut up and use what I have.
12-05-2011, 06:14 PM   #7
Hi guys, are using two cards or just one. Are you writing RAW + JPG or just RAW. ??
12-05-2011, 06:40 PM   #8
Ed Hurst's Avatar
The 645D achieves, by comparison to more mainstream DLSRs, pretty slow write speeds to the card. This is partly due to the huge file sizes, and partly due to the fact (I believe) that the camera contains some systems/components taken from other DSLRs (which is one of the reasons that the camera is relatively cheap - for a MF DSLR). So expectations should not be too high for speeds. As long as you have a reasonably fast card, you will find that getting an even faster card makes zero difference - as the limiting factor is the camera's own write speed and not the card.
Having said that, writing to only one card (rather than both), shooting only one format (i.e. not RAW + JPG) and turning off some of the processing options (e.g. lens corrections) will speed things up somewhat. Personally I leave lens corrections on, but shoot only RAW format; I shoot to only one card, unless I am taking a vitally important picture where speed is not of the essence. That maximises speed. But it will never be a fast camera.
12-05-2011, 07:06 PM   #9
jackinkc's Avatar
QuoteOriginally posted by ACH DIGITAL Quote
I carry two 32 GB cards but only shoot to #1. #2 card is only for the unlikely event that I run out of room. I only shoot in .DNG RAW format.
12-05-2011, 07:11 PM   #10
Thank you for the information. I'm in the market for one and this is what I've been checking for. In comparison to other medium format 40 mpx cameras, is it too much of a difference? Sorry to compare but just need the info..
12-05-2011, 07:42 PM   #11
Having experienced corrupt cards, I always shoot so each RAW shot is saved to both cards--it is like a built-in RAID 1 array. If one of the cards should ever become corrupt, the other will have the image.
Write speeds are a bit of a pain, but nothing you can't deal with.
12-05-2011, 08:16 PM   #12
Anvh's Avatar
QuoteOriginally posted by Ed Hurst Quote
Personally I leave lens corrections on, but shoot only RAW format.
Lens correction isn'r aplied to the RAW file only to the JPGs and the JPG preview inside the RAW.
So in your case you can simply leave it off without any penalty and improve the speed a bit.
12-05-2011, 08:24 PM   #13
jackinkc's Avatar
I think the 645d image quality will compare favorably with any other MF digital. I KNOW pentax lenses are as good as any.
12-06-2011, 06:29 AM   #14
Oh I know for sure (have downloaded several files) they are comparable in image quality. What I'd like to know is writing speed processing compare to lets say PO or HD..
12-06-2011, 12:09 PM   #15
You should be able to contact a dealer to find the write times. Better yet, rent some of these cameras and try them out. It is going to be a rare individual who owns two different MFD systems--not impossible, but really not common.
645d, camera, medium format
PNY Class 10 card inconsistent write speed bwDraco Troubleshooting and Beginner Help 16 07-25-2011 02:21 PM
k-5 write speed qh187 Pentax K-5 & K-5 II 9 03-29-2011 07:00 PM
K7 write/read speed reduction after new firmware... mxlinn Pentax DSLR Discussion 3 10-15-2010 09:09 PM
K-m Write Speed dave9t5 Pentax DSLR Discussion 13 02-27-2009 10:22 AM
SDHC write speed cautious Photographic Technique 3 09-16-2007 02:41 PM
All times are GMT -7. The time now is 05:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
