12-14-2011, 05:36 AM   #1
Top LCD light on the 645D
I've had the 645D for a year, great camera but my top lcd light button has never worked. I don't need it, so no issue. I recently saw a used 645D for sale and the seller says his light has never worked as well. How common is this problem?
12-14-2011, 07:05 AM   #2
No problems and I like the illuminator very much.
12-14-2011, 08:50 AM   #3
Might be a menu setting you inadvertently changed upon setup? It can be toggled to turn on or off via certain buttons on the K-5.
12-14-2011, 08:54 AM   #4
RTFM !!!
Switch custom-menue 5, point 34 back to 1.
The light-bottom should work now.
-Linus-
12-15-2011, 05:16 AM   #5
Thanks Linus.
BTW, I did RTFM; it's not crystal clear that the "off" setting enables the lcd light, or for that matter that the other options disable the light.
12-15-2011, 11:41 AM   #6
Oops, I did not
Oops, I did not
But I guess it's working now?
-Linus-
12-15-2011, 04:34 PM   #7
QuoteOriginally posted by -Linus- Quote
-Linus-
Yes it is, that's why I said thanks. I can't imagine how you knew this.
12-16-2011, 04:07 AM   #8
I had this issue, called Pentax and the tech told me that there was no software switch or custom setting that affects the LCD. My friend Antonio in Caracas sent me a note with the instructions that Linus posted and of course, it works. The frustration here is that the Pentax tech didn't know what he was talking about.
12-18-2011, 06:49 AM   #9
Always thought the light only works when it's really dark
I had the same problem in soft light conditions - the LCD light never worked. I did not change anything in the menue but when I was out there shooting in almost complete darkness: it suddenly worked. Strange, what?
645d, camera, lcd, light, medium format
What is the use of the top LCD with setting values display ? photoleet Pentax K-5 14 09-27-2011 05:53 PM
The missing top LCD panel mrbrightside Pentax K-r 17 12-23-2010 01:14 AM
K-7 top lcd light HeavyD Pentax DSLR Discussion 8 03-31-2010 08:50 AM
Top LCD replacement on *istD Giga_Def Pentax DSLR Discussion 6 02-26-2010 04:16 AM
[K100D] Does top LCD has a backlight? sterretje Pentax DSLR Discussion 3 02-04-2010 07:14 PM
All times are GMT -7. The time now is 06:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
