Originally posted by Yamanobori It is all a matter of registration distance, mirror clearance, and useable image circle. Assuming you can shave the mount the rear element is where it is. The mirror for the 645D is much shorter than for a 645, so this may be doable...assuming that you can machine the lens down enough to allow for infinity focus. (70.87mm - 45.5mm --> 25.37mm to shave!!!) Then there is the issue of vignette.
All of these factors are noted in the article you linked. Whether the same can be done for C/Y to 645D is high dependent on the lens.
