01-10-2012, 05:33 AM   #1
Probably silly question but...
....how do I remove the litttle strap-holders from the camera lugs?
There doesn't seem to be any lever, or other device and they really don't come up off the lugs at all?
Am I missing some "trick"...?
Thanks,
01-10-2012, 05:38 AM   #2
DanielT74's Avatar
Do you mean the little leather thingies on the K-5?
I nearly lost both - they just come off. Turn the metal bits through them.
Or do you mean the metal bits? They come off the same way your key comes off your keyring.
I am probably missing the question here...
01-10-2012, 07:13 AM   #3
6x7
I am referencing the 6x7 in this section.
The 6x7 camera has small metal lugs. The stap has push-on metal devices that go over the lugs easily enough...BUT, how do I get them off the lugs?
01-10-2012, 08:19 AM   #4
Depending on the strap you have, there could be a little metal tab that sits between the camera and the plastic knob on the strap. The tab can be pulled up and this allows the strap to be pulled off the circular tab. It works somewhat like a guillotine - a larger opening allows you to slip the strap clasp over the circular tab on the camera, push the tab down and a smaller cirlcle slide over the small collar of the camera tab, thus securing it. To remove, reverse the process and lift the metal tab on the strap.
01-10-2012, 06:09 PM   #5
DanielT74's Avatar
QuoteOriginally posted by Andy21 Quote
Oops. Turned out it was the stupid answer, rather than the stupid question...
camera, lugs, medium format
Silly Question? - input length for mirror? Docrwm Pentax SLR Lens Discussion 12 06-22-2011 01:15 PM
Probably a silly question clearlybored Troubleshooting and Beginner Help 13 03-21-2011 07:51 AM
silly question - using flash off camera eclipsed450 Troubleshooting and Beginner Help 13 10-02-2010 03:16 PM
Silly Question straightshooter Pentax Camera and Field Accessories 32 06-17-2010 11:52 AM
Silly Noob Question: Bokeh twokatmew Troubleshooting and Beginner Help 5 03-26-2010 07:14 PM
All times are GMT -7. The time now is 01:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
