Originally posted by Ed Hurst I think you will find them both competent performers on your K5, but probably no better than lenses of equivalent length made for the smaller format (and perhaps not as good). Why not try them and see?
Now if you had said you have a 645 A 35mm, or a 120mm (A or FA) or 150mm FA or the 300 f4 I would have said expect to be very pleased! A couple of the 67 lenses likewise would be every bit as good as a first rate smaller format lens.
I tested both lenses on the K-x with the Pentax adapter. The 75mm is good but a tad less sharp than the SMC Takumar 1.8/85mm was. However, I did not have to dial in any compensation, unlike said Takumar, so it was much more user-friendly and the difference was not all that noticeable. My 645 A 35mm was in fact sharper and nicer than 3 equivalent lenses for Pentax, but then again, that is a really nice lens. I would not use 645 lenses however, apart from the A 120mm because it is a Macro lens which I have used for some product photos. The 645 A * 300mm was sharper than the K version, but I was always afraid it would damage the camera because of its weight....
In the end, it is about practicalities, as long as IQ is not too starkly different. I'd use 135 lenses on a 135 or APS-C camera.
