01-29-2012, 08:11 PM   #1
Marketplace Reseller
Firing a shot without a lens?
I don't want to waste a shot with my Pentax 645 to answer this question.
Will the 645 fire off a shot if there is no lens on the camera? If not do adapters like the kiev 88CM move a lever or short out contacts to tell the camera there is a lens mounted?
Thanks in advance
01-29-2012, 08:24 PM   #2
Mike Cash's Avatar
Couldn't you try it with no film in the camera?
01-29-2012, 09:27 PM   #3
Venturi's Avatar
I just verified with mine. The 645 will:
  • With no back attached fires @ 1/1000s with or without lens mounted.
  • With an empty back it will not fire, period.
  • With the test back/cover operates as if it had film loaded, and it will fire without a lens attached.
01-29-2012, 10:16 PM   #4
QuoteOriginally posted by Venturi Quote
I was under the impression and i may be very wrong. but that the test back would fire shots without a lens attached however the camera knows its a test back (no attempt to wind the film i think but then i could be wrong) whereas with film it may not.
01-29-2012, 10:49 PM   #5
Venturi's Avatar
It's running the motor, whether it has the film advance engaged I can't see (obviously).
01-29-2012, 11:08 PM   #6
Thanks Jim
camera, lens, medium format, shot
Shutter firing randomly IanF Pentax K-r 2 01-19-2012 08:25 AM
Anyone else have problems with pop-up flash not firing? einstrigger Pentax K-r 7 09-17-2011 02:35 PM
Cactus 4's Not Firing with ISO 100 (K5) Deiberson Flashes, Lighting, and Studio 2 06-22-2011 08:26 AM
long range remote firing for K10D or Kx Glen_S Pentax DSLR Discussion 17 03-05-2011 08:02 AM
NPR firing jeffkrol General Talk 52 11-01-2010 12:04 PM
All times are GMT -7. The time now is 07:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
