Originally posted by Yamanobori It is great if you really want to control exposure and development, but I can get just as accurate meter readings with less effort from an incident meter--I have and use both. I think an incident meter would be a much better match for the OP. There are incident meters that can take a spot attachment later on. And if you are doing street/people type of work, a spot meter is really not that desirable.
There is a real art to using meters consistently and the learning curve with a spot meter is steeper.
JMHO
I agree your recommendation would be better for the OP too. And mine is for when you want more info or control. I'd note, however, that a one-degree can be time consuming to use at first. But after a while it can be really fast. Take people pictures for instance. From the camera's position, I can take one reading off a person's skin and you're done if that is the most import thing in the scene.
Similarly for other scenes. I often can walk up to a scene and know right away what is the most important value to capture, take one reading (from a distance!), place it and shoot. But other times I take many readings and ponder. Those scenes would most likely be the scenes average meters have a hard time with anyway and take human intervention.
