02-03-2012, 08:52 PM   #1
Dubesor's Avatar
6x7 Lenses on 645n & Stop-down Metering Trouble
I've had an exposure disaster on a recent photo trip that was quite disappointing. I want to make sure it won't happen again.
I was shooting with my Pentax 645n and two lenses - the native 645 FA 75/2.8 and the 6x7 Takumar 55/3.5 (using the Pentax 6x7 to 645 adapter).
The 6x7 lens overexposed a lot when stopped down. I haven't had this problem shooting wide open. On the other hand, the 645 lens produced correct exposures with the camera's built-in meter, as always...
Just to confirm, to use stopdown metering, I should keep the camera in "A" mode and flick the switch on the lens to "AUTO"?
I did that and stopped down: the metered shutter speeds got progressively longer which seemed OK (but turned out very inaccurate at smaller apertures, as I mentioned).
02-03-2012, 09:13 PM   #2
You don't even need to stop down meter with 6x7 lenses, do you? I know you don't on the 645d.
02-04-2012, 11:05 AM   #3
I'm thinking that your lens should have been set to "manual" for your body to meter correctly.
02-04-2012, 05:38 PM   #4
Otis Memorial Pentaxian
I am with Adam. A properly adapted 6x7 lens should function with open aperture metering and support auto-exposure on your 645N. No stop-down required. It sounds to me like you are metering stopped down and shooting wide-open.
02-04-2012, 07:03 PM   #5
Dubesor's Avatar
Good advice all! I'll try keeping the lens switch in MANUAL instead. For some reason, I thought it had to be AUTO (maybe based on M42 Takumars I used before)
645n, 6x7 lenses, camera, lens, lenses, lenses on 645n, medium format, pentax
Pentax Medium Format Resources: 645 & 6x7 Cameras and Lenses, 645 & 6x7 Accessories Adam Pentax Medium Format 9 02-12-2017 03:38 AM
K-X stop down metering problems with fast lenses i_trax Pentax DSLR Discussion 3 07-27-2011 06:00 AM
Pentax 645N: metering with manual lenses psychoanalyst Troubleshooting and Beginner Help 3 07-14-2011 10:33 AM
Auto Lenses on Pentax Kx..stop down metering..HELP CLYNN0928 Pentax DSLR Discussion 7 11-10-2010 03:54 AM
K-x Stop-down metering with m-42 lenses Bazwell Pentax DSLR Discussion 8 11-20-2009 12:57 PM
All times are GMT -7. The time now is 08:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
