Originally posted by Digitalis It never ceases to amuse me how people just look at the resolution count of the camera and assume the output will equal or better that of any other camera that is within 2Mp+/- of it's MP count and completely ignore the size of the sensor. I agree that the D800E will have output that is similar to that of the 645D in terms of resolution, however the overall IQ from the 645D will be higher because the sensor is bigger, the pixels are bigger, and there is much less strain put on the lenses with the sensor used in the current 645D than with the D800E. Nikkor lenses are very good, I own a decent sized collection of them that I work with, but in the area of wide-angles there are going to be some problems with image quality in the corners that are going to be exacerbated but the high resolution of the sensor. Canon photographers have pretty much given up the hope of ever finding a prime, or zoom wider than 20mm* that doesn't have horribly smeared corners.
*truth be told the Nikkor 14-24mm f/2.8G ED lens is absolutely stellar, but in the end it is a rather specialised and expensive lens....and prone to flare.
I'd like to get a 14-24 adapted to the 645D...that would be a helluva combo. 14-24 is the god of wide angles.
Thought about going Nikon D800 and not a 645D But the square footage of the 645D sensor is roughly 68% larger than the D800's sensor. (If I figured it right??) So even if the Nikon was 40mp it would still be 68% behind the 40 mp 645D.
If anyone is mp crazy they should go for the 80 mp Mamaya for $38,000!
40mp is more than fine for me. The only thing I wish Pentax had done was to make the 645D run on 4 AA's. And maybe some built in HDR ability.
