03-15-2012, 12:15 PM   #76
JinDesu's Avatar
QuoteOriginally posted by Anvh Quote
test photos, RAW and jpg online.
Not the E version though
Nikon D800 Camera Samples - First Shots
Much better samples!
But definitely does not beat the 645D then.
http://www.imaging-resource.com/PRODS/645D/645DA7.HTM
Selecting the ISO100 NR off sample, you can definitely see more detail in the 645D pictures - as well as being more MP anyways. Is it worth the $7000 difference? I don't know!
So it looks like the D800 is pretty damn good.
03-15-2012, 12:29 PM   #77
QuoteOriginally posted by JinDesu Quote
Pentax 645D Camera Samples - Initial Test
The difference in pixels is less than 4% in resolving power. Not really a factor. But it is a good thing the Nikon has an AA filter or the beer label would have moire too.
Since I have been taking pictures for more than a year equivalent to about $4700 in film and processing costs, the difference is only about $2300 now and I still have to wait.
03-15-2012, 01:01 PM   #78
Anvh's Avatar
QuoteOriginally posted by Yamanobori Quote
Is it really that bad? If so than i'm curious about how useful the D800e version will be...
03-15-2012, 01:38 PM   #79
eddie1960's Avatar
not so sure it's as bad as it's made out myself. a number of excellent cameras have no AA filter (though they all are CCD technology)
03-15-2012, 03:05 PM   #80
bossa's Avatar
I use the Pentax SMC 43mm f/1.9 special - in Leica 39mm screwmount and it performs superbly on the full frame 18Mp Leica M9 - the 43mm is particularly impressive at f/4 where it rivals the resolution of the Leica summilux-m 50mm f/1.4 ASPH, and the Pentax lens has superior flare tolerance compared to the Leica 50mm lens.
That's the important thing here. If the sensors have the same (or close) pixel number but one is APS-C and the other a FF, then the lens on the FF is NOT magnifying the lens faults whereas the APS-C is actually magnifying them 1.5x. So all the nasty stuff people expect from the lenses don't show up until you get a 36mpx sensor that people immediately start pixel peeing on to see how much they can get out of it. Don't forget that smaller pixels also record camera shake a lot more too.. I'm starting to think that Nikon should really have produced a 24mpx FF instead of the D800 now.
Thanks for that gem of a line Doug.
03-15-2012, 03:56 PM   #81
Did you look at the 100 ISO sample image from the 645D?
03-16-2012, 02:46 AM   #82
Roberts's Avatar
QuoteOriginally posted by chicagonature Quote
Nikon D800E vs. D800: Which is more Diffraction Limited?
The Technical Guide to the Nikon D800/D800E was just published and I believe it is saying that the D800E (the one with effectively no anti-aliasing filter) is more Diffraction Limited than the D800. Here's the quote, "The D800E offers better resolution at apertures where diffraction is not an issue. The effects of aperture may therefore be more noticeable than with the D800, and care may be required to avoid loss of definition due to diffraction." Does this makes sense from a physics point of view? I mean, shouldn't it be just the opposite of what Nikon is saying because the Nikon D800 is causing the Airy Disk to be a little bit larger due to the increased blurring caused by the anti-aliasing filter? Plus, Nikon uses the word "may" and they show images from the D800, not the D800E. It's confusing.
I guess they meant that on D800E because of more clearly visible details there is more visible effect of diffraction, too.
Quote from todays article on Luminous landscape Nikon-D800-or-D800e :
"Use the optimum aperture. Apertures below about f/11 introduce diffraction and effectively act as an unintentional AA filter"
03-16-2012, 03:24 AM   #83
So if you have the 800E and need a little AA filter, you just have to stop down? Two cameras in one!
03-16-2012, 03:42 AM   #84
JinDesu's Avatar
QuoteOriginally posted by Roberts Quote
Will it get rid of the moire effect in patterned surfaces?
03-16-2012, 03:55 AM   #85
Digitalis's Avatar
yep, that is how I deal with patterned surfaces that cause moire with my Leica M9 - though most RF lenses only stop down to f/16. But diffraction will also kill detail in pretty much everything else too.
03-16-2012, 05:48 AM   #86
Coeurdechene's Avatar
QuoteOriginally posted by bossa Quote
Remember: the d800 has about the same pixel pitch as the k5, the size of the pixels is very similar...have you got problems with camera shake on your k5? if you haven't you will not have them on the d800.
Also Camera shake is much more visible if viewed at 100%...if your viewing size is small you won't see more camera shake than with a 12MP sensor...Camera shake negates some of the advantage of the high resolution but it does not make things worse than with lower MP cameras. Bottom line if you want to fully profit from the higher resolution you got to use a faster shutter speed or a tripod. If you don't need huge prints you can still use the d800 as it was a d700 and get good results for a moderate print size.
03-16-2012, 06:04 AM   #87
Anvh's Avatar
Yes but i haven't seen the images of the D800 because i ain't behind my pc, that's why i asked for a bit more information.
I have even worked with the 645D, it's an amazing camera but a bit slow though.
I'm waiting for the upgrade, the new processor and UHS sd-bus would be a nice upgrade, they can keep the sensor because it's really good.
03-16-2012, 06:07 AM   #88
Digitalis's Avatar
QuoteOriginally posted by Coeurdechene Quote
The D800 doesn't have in-body image stabilisation so that is a bit of a pointless comparison. With my D3s camera shake isn't an issue hand holding a 50mm lens at 1/4th second shutter speeds - VR lenses extend hand holding techniques to produce sharp results even at 1s.
03-16-2012, 06:34 AM   #89
Anvh's Avatar
At longer shutterspeed the shake of your hands isn't the problem but it's damn hard to keep the camera pointed the right direction XD
03-16-2012, 06:37 AM   #90
RonHendriks1966's Avatar
QuoteOriginally posted by jwoodland Quote
On the chance of asking the stupidest question of the year:
Can you put a filter on the lens that has the function of a missing AA filter?
645d, camera, d800, medium format, nikon, pentax
645D vs Nikon D3x, What should we test? Adam Pentax Medium Format 76 12-03-2011 08:35 PM
Pentax 645D vs Nikon D3x Review Discussion Adam Pentax DSLR Discussion 48 12-03-2011 08:31 PM
Pentax SMCP-FA 645N 80-160mm f/4.5 lens on Pentax 645D Imatest results JDOAK Pentax Medium Format 6 01-23-2011 12:56 PM
645D vs Nikon D3x steve perry Pentax Medium Format 20 12-05-2010 06:16 PM
Pentax 645D vs Nikon vs Canon yurihuta Pentax Medium Format 4 04-23-2010 03:44 PM
All times are GMT -7. The time now is 02:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
