03-21-2012, 12:53 PM   #1
klaus123's Avatar
Strange detail at fisheye 35/4,5 (solved)
Hello
Recently I bought a used fisheye for my 67. When I received it I found, taht the rear plate was bended. I tried to compllain, but finally I accepted it because it does not have any negative impact on the results.
Now I have seen an other auction of a fisheye at ebay - and saw in the pictures that it is obviously an intended detail (see photo).
Has anybod an idea what this bended disk is for?
03-21-2012, 01:14 PM   #2
Ole
Ole's Avatar
My guess: make room for the mirror flipping up.
03-21-2012, 01:48 PM   #3
klaus123's Avatar
But the bending direction is TOWARD the mirrow!
03-21-2012, 02:52 PM   #4
I have the Pentax SMC 67 45mm F4 lens, and this lens has the same metal plate. I called my Pentax repairman about this, assuming this was the result of some kind of impact damage. He told me that this device is meant to be used for attaching gelatin filters to the back of the lens.
03-21-2012, 02:54 PM   #5
It is a gelatin filter holder. You slide the filter under the ring behind the lens.
03-21-2012, 10:10 PM   #6
klaus123's Avatar
Thank you - thats a good explenation
03-24-2012, 02:33 AM   #7
QuoteOriginally posted by Yamanobori Quote
Right, but they are glass filters.
You get a UV (clear), green, yellow/red and ND screw in glass filter with this lens.
Preferable you should use the lens always with a screwed in filter (mostly UV [clear]), because the optics are calculated with the filters.
With other words without a filter the optics are missing something ,)
03-24-2012, 07:55 AM   #8
gofour3's Avatar
QuoteOriginally posted by veraikon Quote
The Pentax 6x7 35/4.5 fisheye has four built-in filters: UV, Yellow, Orange and Red. They are selected via a filter dial located near the front of the lens. If you want to use another type of filter then these would have to be gelatin and inserted in the rear holder. There are no front filter threads on this lens, so you can’t use regular glass filters.
Phil.
03-24-2012, 10:14 AM   #9
ok, my mistake. I didnīt see the Pentax 67 - I only saw the fisheye - and with the other fisheye you have to use screw in filters , which are screwed in at the back. .
camera, detail, fisheye, medium format
Landscape The color of the detail esseti Post Your Photos! 6 10-11-2011 10:18 PM
Macro Let there Bee Detail eaglem Post Your Photos! 8 09-28-2010 12:36 AM
Architecture Building detail slowpez Post Your Photos! 3 06-02-2010 05:42 PM
catching sky detail with people detail Genshu Pentax DSLR Discussion 6 04-15-2010 06:40 PM
All times are GMT -7. The time now is 08:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
