03-23-2012, 07:38 AM   #16
QuoteOriginally posted by itshimitis Quote
Don't think it will be as expensive as that UK price £3700
Hmm Photoscala is normally correct:
Markteinführung / Preis: Die Auslieferung des smc DA 645 25 mm / 4 AL [IF] SDM AW Objektiv wird wahrscheinlich ab April erfolgen. Der Preis liegt bei ca. 4.800 Euro bzw. 5.999 CHFr.
Perhaps the £3700 is without VAT. ?
03-23-2012, 07:54 AM   #17
This has no consequence to me, but wow... if they are going to sell the cropped lens around the same price as the D-FA and only to foreigners... That's a real **** move on Pentax's part. I would think at that price they could manage to fill the entire frame of standard 645.
03-23-2012, 08:52 AM   #18
Ryan Tischer's Avatar
I guess this sort of makes sense, but wish they would pass on the savings to the customer for the DA 645 25mm! I am curious how different the performance will be between the two lenses on the 645D?
03-23-2012, 09:07 AM   #19
QuoteOriginally posted by veraikon Quote
Hmm Photoscala is normally correct: Perhaps the £3700 is without VAT. ?
£3799 including VAT although described as DFA, Ffordes sell only stock imported for the UK:
DFA 25mm F4 AL IF SDM AW by Pentax - Ffordes Photographic
03-23-2012, 09:59 AM   #20
Topace said above: "D-FA isn't quite compatible either. They lack aperture rings, and the 645 film cameras can set aperture electronically if in shutter priority mode, but not otherwise."
Don't the latter film bodies (the N and Nii) have electronic aperture control in the body, making the first variant of this lens fully compatible? Obviously the original 645 film body lacks this...
But it seems to me that the main point here is that this signals that there won't be a full frame 645Dii.
BTW, note there is no crop-only version of the DFA 55mm
03-23-2012, 10:56 AM   #21
You're right Ed, the N and NII allow electronic aperature control when the lens aperature is set to "A". I'm very concerned that the 25mm is now a D FA lens implying no full frame 645DII; Pentax made a mistake converting from FA to D FA in the 35mm lenses and now seem intent on repeating it.
03-23-2012, 03:50 PM   #22
Zygonyx's Avatar
QuoteOriginally posted by Ayoh Quote
It makes a bit more sense now:
"Changes or improvements to the predecessor model:
Due to the high manufacturing effort for a lens with an image field illumination for the analog Pentax 645 system has decided to offer this focal length in two variants.
Option 1 - DFA 645 25 mm due to the large spread of the analog 645 system exclusively for the Japanese market
Option 2 - DA 645 25 mm, this lens is intended for distribution outside of the Asian market"
Hello Ayoh, where do you quote this from ?
03-23-2012, 04:43 PM   #23
topace's Avatar
QuoteOriginally posted by Ed Hurst Quote
645N can set the aperture when the lens is in A mode or lack aperture ring, yes. But unless I've missed some controls on my 645N (I didn't read the manual, since the camera's normally so easy to shoot with), it does not have an interface to set it in AV or M mode, only TV or P. It seems that MZ-S has the same problem in small format.
Feel free to correct me if I'm wrong.
03-23-2012, 11:07 PM   #24
Hi
I stated this elsewhere but I think it might be germain to the discussion. I don't think this revised lens necessarily means that there will be no full frame 645D. It appears that to align the image circle perfectly with the older model lens for use on full frame, it might have been a labor intensive effort and many samples initially didn't cut it. Therefore to streamline production and make things easier to adjust in assembly, modifications were made to the lens and the image circle and alignment just has to be a bit greater than that needed for the cropped 645D sensor. Theoretically, the new version should be less expensive but Pentax might not want to offend those that already spent money for the older lens for use on their 645D.
Dave (DandA)
03-24-2012, 02:54 AM   #25
QuoteOriginally posted by Zygonyx Quote
It is a translation from the photoscala article (en allemand ) - link above
03-25-2012, 10:46 AM   #26
QuoteOriginally posted by DandA Quote
Nikon migth not want to ofeend those that already spent money for the older lens
I think you meant Pentax I doubt Nikon would mind if Pentax offended their customers!
03-25-2012, 12:59 PM   #27
drougge's Avatar
It's the other way around actually, the original Pentax 645 can use aperture priority with the lens in A mode, 645N and NII can't. (See page 36 in the 645 manual, and page 40 in the 645N manual.) All of them can of course use lenses in A mode with shutter priority or in program mode. I don't think any of them can use the new lenses in bulb mode unless you want the smallest aperture.
03-25-2012, 10:22 PM   #28
QuoteOriginally posted by Ryan Tischer Quote
Hi Ryan,
Yes, of course I meant "Pentax" not "Nikon" in my posting above. That wasn't the only necessary changes to my previous post, so I made a multitude of changes, and therefore reads much better and now makes sense. Thats what happens when I try posting from my tiny cell phone Thanks for pointing out the typo!
Dave
03-28-2012, 05:09 PM   #29
Pål Jensen's Avatar
QuoteOriginally posted by Smolk Quote
I read somewhere that the lens hood is now designed to cover the cropped sensor of the 645D, rather than the FF. That may influence flare-resistance of course.
More ominously, perhaps the move implies that plans for a FF sensor have been shelved.
Actually, it might as well indicate the oposite. It may be that Pentax have figured out that this lens do not meet the standard for an FF 645 sensors (eg edge definition), and instead of giving the lens a bad reputation, they marked it as for cropped sensors only (the need for a 25mm on a FF 645 is debatable as it is extremely wide). Otherwise, it would be weird to keep the D-FA label on the new 90mm if there were no FF in the plans....Why not call all 645 lenses DA then?
03-28-2012, 05:11 PM   #30
Pål Jensen's Avatar
Doesn't make much sense really as they sell both at the same price. Why not sell the D-FA in all markeds?
camera, medium format
D-FA 25mm in stock revdocjim Pentax Medium Format 12 04-18-2012 05:57 PM
25mm Examples lnorton Pentax Medium Format 23 12-09-2011 05:15 PM
A cheap 25mm fs999 Pentax Medium Format 5 09-12-2011 02:43 PM
Voigtlander 25mm f/0.95 pretty please Singulariter Pentax SLR Lens Discussion 3 11-15-2010 10:32 AM
All times are GMT -7. The time now is 10:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
