Originally posted by pxpaulx The updated menu would be for use with the newer GPS hotshoe accessory, the Pentax O-GPS1 - it isn't compatible with other branded handheld units. I've used a delorme PN-20 for some time, works well, good 8-10 hour battery life (runs on AAs), and the GPS track can be exported if you want to use it to tag your photos and pin them on a map - just need to make sure the times are correlated. The Pn-20 is a couple years old now, probably find it on ebay well under $100 used (good price as long as software and maps are included).
Thank you. I haven't heard of the Delorme before, and don't think they are sold in the UK, so maybe there would be a map problem. I'll have a look at the PN-20 in more detail and see which UK Garmin or Magellan model most resembles it.
