05-13-2012, 12:33 AM   #16
I have three AP6x7 bodies: two have so-so metering prisms, one has a meter-less prism.
Consequently, I use a hand-held meter for all my shots, including macro with or without tubes, with or without the dedicated Macro lens (tubes and the 105mm standard lens works well too, as does the 4/135 Macro lens together with a 4 diopter accessory lens).
I use the formula Exposure Factor= (1+Magnification)squared
Seems to work OK.
05-13-2012, 02:27 PM   #17
gofour3's Avatar
I’ve been fooled into thinking my TTL meter also doesn’t work when it did. The issue was the shutter speed and aperture were not set fast enough for the meter to register.
If you are using extension tubes the amount of light hitting the meter will be lower than with a regular lens attached. Try setting the shutter to 1 second and the lens to the maximum aperture to see if the meter registers.
Phil.
05-18-2012, 06:03 AM   #18
QuoteOriginally posted by gofour3 Quote
Iíve been fooled into thinking my TTL meter also doesnít work when it did. The issue was the shutter speed and aperture were not set fast enough for the meter to register.
Phil.
this wasnt the case i was testing it shining it into a strong light at 1 sec and no response. My tubes did not activate the metering leaver which the lens normally does, but the tape does work to then use manual stop-down ttl metering
camera, extension, lens, medium format, meter, moves, ttl meter, tubes
Spotmatic light meter not responding to aperture squido Pentax Film SLR Discussion 3 08-10-2011 12:23 AM
K-x won't stop-down meter while using extension tubes? MikeS Pentax DSLR Discussion 37 05-28-2011 10:52 PM
Extension Tubes for K7 Alex00 Pentax SLR Lens Discussion 6 05-31-2010 09:23 AM
All times are GMT -7. The time now is 06:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
