Originally posted by Yamanobori The only advantage to the 300mm f/5.6 over the f/4 lens is weight and size. You also get a closer minimum focus distance--2.2m vs 3m. I bought the f/5.6 for the weight and size as I haul my stuff manually--can't get the donkey in the car, so I have to be able to cary everything when I get where I am going and still be able to work. But contrast is low with that lens. It is not a focal length I use often, so I am happy with the compromise.
I also shoot with the D FA 55mm, A 120mm Macro, and A 35mm. I am very pleased with those lenses.
As I mentioned in my previous post (and my comprehensive testing of lenses)....when each of tjhose 300mm AF 645 lenses are compared, when used wide open, the difference in contrast and micro contrast between the two is quite significant and in many shooting circumstances have substantial impact. the FA 300 f4can be used quite confidentially wide open. The 300 f5.6 on the other hand generally requires some stopping down to achieve something close to a compreable image as compared to the FA 300 f4, but if you shoot it stooped down, it is a very good lens. It all depends on needs and of course as you mentioned, ease of traveling with it.
Dave (D&A)
