Originally posted by germar Thanks, all. I wound up buying the 645, along with a 75mm LS 2.8 and a 120mm f4 macro for a nice price. The seller had stuck an ancient roll of Porta 160 in there so all the functions could be checked. I'm running a fresh roll of Ektar through it now and we'll see how the images come out. I have high hopes.
Being as it is a Pentax and has really good Pentax glass on it, your hopes are justified!
The only thing these cameras are supposedly not good at is metering and setting the exposure accurately for slide film. Ken Rockwell says the camera only meters by full stops, but he's wrong. He also says you can compensate for third-stops by adjusting the camera's ISO setting...but that is also wrong. He thinks that by changing the ISO you slightly tweak the exposure, but you don't...you'd get the same nearest full-stop, since tweaking the ISO in third-stop increments would only change how it meters, not how it sets its exposure.
IF you shoot aperture priority, the camera can only change the shutter speed by full stops. Actually, I thought I read in the manual that it indicates the nearest full stop but it's actually stepless, though I don't have proof of that.
At any rate, even if the shutter DOES meter by only full stops, in Program or Tv, the camera can adjust its aperture by half stops, and there are half-clicks on the aperture ring, too.
Did
any of that make sense?
