06-23-2012, 10:21 AM   #16
Zygonyx's Avatar
We will be keen to know what kind of "litle things" do annoy you, are they different from the D-FA version ?
06-24-2012, 11:16 AM   #17
Where did you buy it? I just stayed in line with B&H, but perhaps Amazon, Pentax, or Samy's are better?
06-25-2012, 05:08 AM   #18
For ND graduated filter holder
QuoteOriginally posted by Ryan Tischer Quote
For graduated ND filters a filter holder is absolutely necessary, which is necessary for many landscape scenes that include the sky. Of course, you can exposure bracket, but if you're also focus bracketing that is one more thing to potentially go wrong...
I'm not sure what other people have done for fitting ND grad filters, and presumably the Lee push on holder (made specifically for the Nikon 14-24 lens) doesn't work?
It might be worth trying this company http://www.skgrimes.com/home who are well known for designing and making specific parts for large format cameras.
Can I ask with the focus bracketing, is this something you do always, or is the 25mm lens quite hard to focus? I don't have this lens, but is it similar to the A 35mm lenses where you can pretty well focus at infinity and everything from 15 feet outwards should be sharp?
06-25-2012, 06:03 AM   #19
QuoteOriginally posted by Lacunapratum Quote
I bought it at headshots in Toronto.
06-25-2012, 06:06 AM   #20
QuoteOriginally posted by Zygonyx Quote
For one, the auto focus is rather slow, or feels slow compared to other lenses I have used. Also, because the lens has quite a deep depth of field it's really tough to focus manually as pretty much everything appears in focus in the viewfinder.
07-06-2012, 07:51 AM   #21
I started to put some of my first impressions of the lens on my blog: Pentax 25mm review
07-06-2012, 08:24 AM   #22
Thanks larkis. Nice report.
Loved the wall shot. Very colorful. Have you tried correcting the CA's with any software? How does that work out? I've neevr tried it, but heard it can be done.
07-06-2012, 08:55 AM   #23
I will be posting more on CA today or tomorrow. There are some special cases with it and I have some samples of the extremes. Usually it's not an issue but I have a few images that have pretty extreme CA that can be corrected in post to some degree.
07-06-2012, 10:08 AM   #24
Zygonyx's Avatar
Thank you larkis for theses usefull considerations.
Re. exifs informations, the D-FA version seems to be completely identified with my tools : ACDSee, Silkypix, flickr.
So i guess it is a matter of lens FW.
07-06-2012, 10:30 AM   #25
eddie1960's Avatar
QuoteOriginally posted by larkis Quote
I didn't realise they had the 645D there now (it's just around the corner but I hardly ever go in) Are they renting for it as well?
07-06-2012, 10:30 AM   #26
I can answer one question for you--there must be a filter in the lens at all times, which is why they give you a blank filter. Since the filter is inside the lens, the thickness of the glass is part of the optical formula. If you remove the filter, it will shift focus.
07-06-2012, 11:48 AM   #27
Ryan Tischer's Avatar
QuoteOriginally posted by Yamanobori Quote
Thanks for the info, I was wondering this as well. I assumed it would be better to leave one in vs. not, as it only came with one filter case.
07-06-2012, 12:37 PM   #28
Zygonyx's Avatar
Interesting explanation
07-06-2012, 01:58 PM   #29
The general requirement of keeping a filter at "in" all times inside a pull out filter draw has been a long standing practice of most lens manufacturers as it"s part of the computated optical path. It's usually stated in the paperwork shipped with a lens, but not always.
Larks, enjoyed reading your blog and your initial Impressions of the 25mm. This lens possibly exhibiting field curvature doesn't surprise me. The Pentax FA 35mm f3.5 645 lens also exhibits a fair amount depending on focusing distance. Generally it's a consequence of extracting additional resolution and this phenomenon is often seen in wide angle lenses where higher resolution is given priority over distortion and field curvature. Often a compromise of both is reached. Looking forward to more of your observations. Thanks! !
Dave (D&A)
07-08-2012, 06:24 PM   #30
I added 3 more sample images to the post
camera, lens, medium format
Overpriced DA 40mm XS now in stock ;) Adam Pentax SLR Lens Discussion 13 06-01-2012 02:03 PM
New DA 25mm mah4ever Pentax Medium Format 53 04-16-2012 10:23 AM
overpriced lenses dankoBanana Pentax SLR Lens Discussion 70 07-23-2011 07:18 PM
Overpriced 6x7 an_d Pentax Medium Format 6 05-07-2010 10:08 PM
Overpriced? I should think so ftpaddict Pentax Film SLR Discussion 3 01-09-2008 09:54 AM
All times are GMT -7. The time now is 07:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
