07-09-2012, 04:14 AM   #31
Thanks larkis!
09-30-2012, 02:22 AM   #32
New Hasselblad 24mm comes in at 6K USD. So comparitively the Pentax can be had cheaper.
They both have advantages and disadvantages though. The Hassy takes large front filters while the Pentax uses drop in filters. So ND and polarizer are cheap while use of grad ND becomes difficult; just the opposite for hassy. Pentax has WR while Hassy can use their tilt-shift adapter and is smaller. But comparatively I think the price for the Pentax is quite good from a specs perspective. The final question though is does the Pentax perform up to standard optically which I can't comment on. Rummor is the Pentax has some CA issues.
Now if only we could get a Hassy to Pentax adapter like the Hassy to Leica adapter choices would open up...
http://www.hasselbladusa.com/media/4232692/hcd24%20uk%20v1.pdf
And of course the Pentax is starting to show up used a bit so it can be had for a further reduced price:
http://www.ebay.com/itm/PENTAX-SMC-DA-645-25mm-f-4-0-AL-IF-SDM-AW-Lens-/2308...item35bff85d1d
09-30-2012, 11:02 PM   #33
QuoteOriginally posted by atlnq9 Quote
PENTAX SMC DA 645 25mm f/4.0 AL IF SDM AW Lens 027075215177 | eBay
I wish I had known that D FA 25mm was for sale as at that price (or near it), I would have strongly considered it. Still all in all, its a expensive piece of glass.
Dave (D&A)
10-01-2012, 01:29 PM   #34
Zygonyx's Avatar
Well, I paid mine around 5100 USD while Euro/USD was around 1,34.
http://www.ebay.com/itm/NEW-PENTAX-D-FA-DFA-645-DFA645-D-FA645-25mm-F4-F-4-S...item5895ffa8b1
10-01-2012, 06:56 PM   #35
Got mine for $5K. Worth every penny for me. Very nice lens. Love the 20mm type focal length in 35mm terms. Hope it covers the new 645Dii.
10-04-2012, 01:39 PM   #36
Ryan Tischer's Avatar
QuoteOriginally posted by Lacunapratum Quote
That's why, in part, I got the D FA version for full frame, not the DA...though that can make it quite a wide lens depending on sensor size of the new 645Dii when it comes out!
12-23-2012, 10:21 PM   #37
I have both 25mm and 35mm, 35mm will be showing more edge distortion, on this point, I would say 25mm is like at least 60% edge distortion less compare to 35mm
01-04-2013, 06:35 AM   #38
I have just bought the DA 25. Weather is horrible so unable to test it out at the moment....
camera, lens, medium format
Overpriced DA 40mm XS now in stock ;) Adam Pentax SLR Lens Discussion 13 06-01-2012 02:03 PM
New DA 25mm mah4ever Pentax Medium Format 53 04-16-2012 10:23 AM
overpriced lenses dankoBanana Pentax SLR Lens Discussion 70 07-23-2011 07:18 PM
Overpriced 6x7 an_d Pentax Medium Format 6 05-07-2010 10:08 PM
Overpriced? I should think so ftpaddict Film SLRs and Compact Film Cameras 3 01-09-2008 09:54 AM
All times are GMT -7. The time now is 07:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
