Originally posted by slackercruster Yow. That is expensive. I take it you don't already have a P645 bellows? One problem with using such a bellows is its depth. It probably doesn't compress to less than 40mm. Add the P645 register of almost 71mm, and you won't be able to achieve infinity focus with anything shorter than a 115mm optic. There's a solution: an M42 focusing helicoid. See below.
First, we need a lens mount. My usual budget approach would be to find some screw-->P645 adapter -- but I don't see any inexpensive ones of any kind on eBay. Mount-reversal ring, plain macro tubes... nada, nothing, zilch.
So my next starting move would be to look for a trashed lens, and remove its mount. Do any other MF bayonets physically fit the P645 mount? Lacking such, another possible starting point is a P645 body cap, and I *do* see one of those on eBay right now for ~US$30.
Next step: turn an adapter or salvaged mount or body cap into an M42-P645 adapter. If an existing adapter has threads, step rings can be used to get to M42. Otherwise, an adapter or salvaged mount can have a wide-flange M42-PK adapter glued to it. The body cap is even simpler: cut a hole in it, into which an M42 male thread will fit. I would insert a shortest M42 macro tube section, thread it into the hole, then glue it in place.
Now we skip the expensive and too-fat bellows and go lean: an M42 16-35mm focusing helicoid, about US$60 shipped from Shanghai to USA. Thread that into the M42 female mount we've attached to the adapter or body cap. On the front of that, add a step-up ring to get from M42 to the optic's diameter.
Quote: What single element lens fits on the front of the bellows?
I suggested either a +10dpt close-up meniscus (FL=100mm) or a +8dpt Raynox DCR-250 (FL=125mm). With my 49mm +10dpt optic (US$10 shipped) I use a 42-49mm step-up ring. With the Raynox (rear thread is 43mm) I use a 42-43mm step-up ring. The Raynox gives better images. The meniscus is cheaper.
The cheapest combo would thus be:
camera --> P645 body cap --> M42 macro tube --> helicoid --> 42-49mm ring --> 49mm +10dpt optic
cost in USD: $30 (cap) + $6 (macro tubes) + $60 (helicoid) + $4 (ring) + $10 (meniscus) = US$110
Next cheapest (and better) combo is:
camera, body cap, macro tube, helicoid --> 42-43mm ring --> Raynox DCR-250
and the cost: $30+$6+$60+$4 (as above) + $60 (Raynox) = US$160 or so.
Yes, either optic will project an image circle large enough for the 645 sensor. For focusing, remember that you need
register + extension = focal length to reach infinity focus, and more extension for closer work. Play with the M42 macro tubes to get the right mix.
