12-01-2012, 08:50 AM   #16
full resolution pictures online !
hello,
my lens finally came back from germany and i made some pictures,
you can find full resolution pictures here: Tilt and Shift sur Pentax 645D , clic on the pictures to download the files,
Christophe
12-01-2012, 09:18 AM   #17
Ben_Edict's Avatar
Hi Christophe
You have made nice work with the view camera parts and the Apo Digitar. Looks solid and well thought out. And your images nicely show the phantatstic image quality of the Digitar. I simply have an adaptor to mount my Pentax DSLRs on the back of my view cameras, but the whole setup is by far not as elegant and transportable as yours. And of course I do lack the Apo Digitar... Would be great to see some more images taken with the lens, which lends itself for architectural or studio work.
Ben
12-03-2012, 04:53 PM   #18
Christophe, Komura made a couple of wide angle LF lenses, the Super W Komura 75/6.3 and 90/6.3, that are more of retrofocus design. You already have a 90mm (and the Komura 90 is huge) but the 75mm is a bit smaller so it may work with your set up. The 75mm will probably require a slightly longer distance to focus at infinity than your current 90mm so it should squeeze in there OK, however I wouldn't expect it to be anywhere near as sharp as your digitar since it was designed to cover 4x5. It is a fairly uncommon lens but not particularly expensive when you do find it - I would expect an EX condition example to cost less than the P67 75mm shift. If you want tilts with 75mm it may be your only option.
12-04-2012, 12:47 PM   #19
Hello,
thank you for your advices,
for the moment I don't really need a wide angle lens for my setup, my pictures are most of the time taken with normal / long lens, even if i have a wide angle in my bag :-)
Christophe
12-13-2012, 10:57 PM   #20
Location: Living in Vancouver, BC, born in Melbourne Australia
Hello Christophe,
I'm very interested in the flag you made with the Gorilla pod leg.
What are the parts you used for this?
Do you have a description of how you put this together?
Thanks in advance.
Andrew
12-14-2012, 03:43 AM   #21
Hello,
it's not easy for me to explain that in english ... you speak french ?
christophe
12-18-2012, 05:59 PM   #22
QuoteOriginally posted by oxonet2000 Quote
Hello,
christophe
Hello Christophe,
I have a good friend who speaks french, so he could translate for me!
Thanks very much - I look forward to hearing from you.
Andrew
12-23-2012, 10:41 PM   #23
Supa!!!
01-24-2013, 03:36 AM   #24
I'm about to change my pentax 645D system for a digital back ( phase one P65+ ), so i think i'll sell the tilt and shift system I made ( including the lens APO DIGITAR 90mm ), so if any body here is interested in buying the tilt/shift adapter , send me an email :-)
christophe
04-26-2013, 03:24 AM   #25
on ebay :-)
you can find on ebay this tilt and shift adapter here: Pentax 645D Tilt and Shift Adapter with APO Digitar 90mm | eBay
christophe
645d, camera, home, lens, medium format, shift, tilt, tilt and shift
645D and Novoflex tilt/shift bellows Femtometer Pentax Medium Format 3 04-25-2012 07:07 AM
Tilt/shift for 645D surfotog Pentax Medium Format 2 06-17-2011 04:22 PM
Misc Pseudo tilt-shift wllm Post Your Photos! 5 11-16-2010 03:19 PM
Tilt shift lenses made for Pentax APS-C bodies Buckeye Troubleshooting and Beginner Help 5 11-12-2010 07:43 AM
My self-made tilt/shift bellows chse Pentax SLR Lens Discussion 22 06-20-2009 08:49 AM
All times are GMT -7. The time now is 02:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
