Originally posted by littledrawe How does the apparent increased magnification of the Q fit into all of this then?
Q has a 5.5x crop factor, but remember that's compared to full-frame. So compared to Pentax APS-C, which is believe is 1.54, that means a lens on the Q is 3.57x that of (say) a K-5. Now, most people are using adapted lenses on the Q for super-telephoto, but to keep in the realm of focal lengths we are used to seeing we might use a shorter length for example. So for instance, to get the FOV that you'd get from a 100mm on the K-5, you'd use a 28mm on the Q.
