11-04-2012, 10:15 AM   #1
6x7 meter works but not with 105
Hi there.
the TTL prism meter on my 6x7 was working great. I was shooting a couple shots yesterday with the 105 and then I went to check the meter reading as the light changed and it would not meter. Meter works just fine with the 75mm, still cannot get it to work again with the 105mm.
I tried dismounting lens and removing prism and putting it back together with the lens in auto and in manual (and in the correct prism>lens order). I can verify the meter is definitely working with the 75 attached, but not the 105.
As I slowly mount the 105, i notice the needle jump, and as i continue to rotate lens to lock position, it immediately drops back down. i also verified that the lens IS coupling with the body/chain and the chain IS coupling with the prism.
I'm stumped!
Hopefully someone can help!!
11-04-2012, 03:11 PM - 1 Like   #2
There is a small pin on the body's lens mount face that can cause problems when a lens is mounted with a poorly machined slot. This is rare and usually causes the meter to work only some of the time.
Also be aware that the TTL has a limited range of what it will meter, especially when using very fast or very slow film.
11-04-2012, 03:22 PM   #3
talking about the recess where the lens lock/release pin fits into?
i noticed that with a lens off and that pin on the body depressed, the meter will respond to manually moving the aperture coupling at the top of the mount.
so i compared both the 75 and the 105 and noticed that pin hole on the back of the lenses. there is also a little piece of metal recessed inside that slot - the one on the 105 looked more flush with the top of the slot, so i poked it back in with a tiny screwdriver. now the meter works with that lens.
strange. i guess i'll keep this little screwdriver in my camera bag in case it happens again.
thank you for your reply! you were spot on!
11-04-2012, 03:45 PM   #4
Glad I could help. Usually it is the outer bay lenses that do this.
11-04-2012, 03:49 PM   #5
Giveaway winner!
MysteryOnion's Avatar
QuoteOriginally posted by rhodii Quote
If it is not aligned properly and although you had "poked" it back, if it moves out again is a sign that the screw that holds it is very loose or that armature is loose.
If it was just bent due to someone being sloppy reassembling it from fixing it, it should stay put from now on.
camera, lens, medium format, meter, prism
sd card works in camera, but is not recognised by pc pieterpost Pentax DSLR Discussion 25 02-21-2016 02:24 PM
Pentax 6x7 TTL meter only works with stopped-down metering trip9 Pentax Medium Format 14 08-11-2011 08:22 PM
kx photo with 55-300mm lens af works,but as a newbe to manual focus litboat Troubleshooting and Beginner Help 4 11-07-2010 05:04 PM
Pentax 67II vs 6x7\67 with handheld light meter iunno Pentax Medium Format 13 11-06-2009 12:07 AM
All times are GMT -7. The time now is 02:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
