12-08-2012, 05:43 PM   #1
bensonga's Avatar
Lens hood for P645 35mm lens
Anyone looking for a very good quality metal hood for your 35mm lens......I can highly recommend this one. I received it on Friday....it's very nicely made! Good price too.
Amazon.com: Bluecell 77mm Wide angle Metal Lens Hood protector for DSLR camera + Bluecell Cable Tie: Camera & Photo
Gary
12-09-2012, 11:37 PM   #2
Ed Hurst's Avatar
Interesting - thanks for the tip!
I would like to find a hood for this lens that is optimal for use on the 645D. The crop factor means that one can get away with a longer hood. I have tried ones intended for standard lenses - they vignette. The generic ones for wide angles I have found look wider (shorter) than they could be for optimal benefit. Can anyone suggest a lens of the quality of the one Gary has found but which is an optimal size & shape for the 35mm on a 645D?
Thanks!
Ed
12-10-2012, 09:10 PM   #3
bensonga's Avatar
Hi Ed. Does the 35mm lens, when mounted on the P645D, have a FOV approximately equivalent to a 45mm P645 lens? If so, I think that's about the same as a 28mm lens on a 35mm camera. So I think a "wide angle" lens hood is still required.....but maybe this one would be worth a look.
Adorama MLH77 77mm Metal Lens Hood MLH77
Or for a lot more money.....this B+H hood
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=11201&Q=&is=REG&A=details
Gary
12-25-2012, 11:02 AM   #4
I use the 35mm A manual focus lens often. Here is the hood I use. It is a 77mm tulip clip on, does not vignette, even when used with a UV filter. Brand name Pearstone from B&H. Highly recommendeed
Dave in NJ
12-26-2012, 12:43 AM   #5
So -- as a new 645N owner, enlighten me -- first, do you HAVE to have a lens hood with the 35mm lens (21mm equiv on the 645N)? Or can you just shield the sun with your hand?
Then... IF you need a lens hood, which of the above would work best on the 645N... where that 35mm lens becomes an ultra-wide?
Just realized that the 645D sensor is actually much smaller than the 645N negative size... so it's a little bit like comparing apples and oranges, isn't it?
Last question -- in the picture above, there are triangular cut-outs on the lens-hood barrel. I've seen this before in pictures of other lens hoods. Is there a reason, or is it just a style? If it would work, I think I'd probably prefer the Bluecell mentioned in the first post -- just because it's smaller. Thanks for any advice!
12-26-2012, 09:39 AM   #6
I use the Pearstone hood with the 645D, where there is, indeed, a crop factor. It my vignette on a film camera. I have no way of checking.
Dave
12-27-2012, 07:51 PM   #7
Another question. Are medium-format cameras subject to more lens flare than cameras with smaller lenses, like 35mms, APS-Cs, and point-'n-shoots? Or is lens flare caused by lens design? Lastly, do wide-angle lens get more lens flare than telephotos? Must confess I didn't do that well in high-school physics, particularly optics!
12-28-2012, 02:14 AM   #8
bensonga's Avatar
I didn't realize that the bayonet/clip on style lens hood would fit on the 35mm A series lens....I thought only a screw in hood would fit. I'll order one of the Pearstone hoods and report back re possible vignetting on a 645N.
12-29-2012, 12:41 PM   #9
QuoteOriginally posted by gurtch Quote
Dave
Is this the one Pearstone LHN-HB39 Dedicated Lens Hood (HB-39) LHN-HB39 B&H
Thank you in advance.
12-30-2012, 07:28 PM   #10
bensonga's Avatar
QuoteOriginally posted by slau Quote
I was just about to order this lens hood from B&H and then I decided to take a closer look at my 35mm SMCP-A lens. I don't see any way that a bayonet, clip on lens hood can fit on the A (manual focus) 35mm lens. There are no bayonet lock groves for it to snap/click onto. From what I can see, only a screw in lens hood would work. So before I order it, I'd like someone to confirm how this or a similar clip on hood would attach to the 35mm A series lens.
Gary
12-30-2012, 11:36 PM   #11
Yes, I also noticed there are nothing on my 35mm A lens barrel to hold onto a bayonet hood, like those on my other FA lenses.
Btw, I have a cheapie plastic pedal type screw-on lens hood that looks like the one recommended by burtch. The lens hood works well with my 35A on 645D, but it is a pain to put it on and off. Eventually, I just left the lens hood most of the time. Still looking for a better one.
12-31-2012, 06:33 PM   #12
Gary -- got a Bluecell 77mm today, after reading your first post above. Low cost, works perfectly... screws right onto any filter I have on the lens, or onto the lens itself. May give a bit of extra protection, too. But I don't think it will stop lens flare resulting from my penchant to have the sun in the picture. Being in Southern California, maybe I need to bring along a noted psychic, or a self-improvement guru, to knock out the flare. We'll see!
A note to anyone interested -- Amazon has shockingly fast delivery of any item they stock themselves, or that they stock themselves on behalf of other vendors. And they are experimenting with same-day delivery right now, in San Francisco. An excellent company.
01-02-2013, 08:51 AM   #13
It is possible to use a generic lens hood which has a ø77 screw on ring on with a bayonet type lens hood that fixes onto that ring (reversible); I have a JJC reversible lens hood for my 35mm on the 645N. It is a matter of precision, as I look through the viewfinder, if the long extensions are horizontal, there's no vignetting, if slightly diagonal then there is. See digitalmediastore: 77mm Reversible Screw-in Lens Hood
Unfortunately my scanner has been in storage for many many months now, and my dark room still awaits transportation, so I have no way to check this on the actual film results (the viewfinder not being 100% it is no absolute guarantee).
The triangular cut-outs help with removing vignetting from the corners, if aligned correctly.
01-02-2013, 04:10 PM   #14
"The triangular cut-outs help with removing vignetting from the corners, if aligned correctly..."
Thanks Smolk... I've always wondered about the cut-outs... the design makes sense now!
01-03-2013, 09:29 PM   #15
I bought one of those hoods from amazon as well, nicely made. Order three other ones from him as well, so I got the "free shipping". All are nice hoods.
camera, hood, lens, lens hood, medium format, metal
Why isn't there an official lens hood for DA 35mm sany Pentax SLR Lens Discussion 14 06-17-2011 04:03 AM
ACR Lens Profiles for P645? MetaD Pentax Medium Format 5 05-23-2011 12:39 PM
Lens Hood for DA 35mm F2.4 AL Jordan Pentax SLR Lens Discussion 13 11-16-2010 12:27 PM
For Sale - Sold: Takumar 49mm lens hood for a 35mm/F2 or 35mm/F3.5 with case SteveM Sold Items 3 11-24-2009 05:39 PM
All times are GMT -7. The time now is 03:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
