01-13-2013, 07:02 AM   #1
Custom 40mm shift lens for 645D
I am pleased to write here for the first time to show you my custom shift lens.
It is based on Bronica ps 40mm lens. I've bought an hartblei 45mm shift only version sometime ago via ebay.
The lens looked great but the image quality was no good. The very left side of the image was terribly soft.
I was doubt for misaligning lens elements so I wrote an e-mail to someone in hartblei.kiev.ua site asking for any
possibility to fix the lens. No response at all even though I was thinking to purchase a new one and this was commented in that mail.
Anyway the shift assembly of the hartblei lens was very helpful for making this custom lens.
The result is much better than hartblei in image quality.
Less distortion, less soft corners, shift within 7-8mm is acceptable.
Only looking strange and working a litte cumbersome.
PENTAX 645D  Photo
PENTAX 645D  Photo
01-13-2013, 07:13 AM   #2
That is a great idea! Does it work as an adapter, where you could put in other Bronica lenses?
01-13-2013, 07:21 AM   #3
Thank you. The shift assembly has to be combined with bronica 40mm lens completely. It can not be used as an adapter.
01-13-2013, 08:05 AM   #4
panoguy's Avatar
So this is the shift and 645-mount part of the original Hartblei permanently attached to the Bronica lens? Very cool, but sounds complicated.
Is there vignetting within the (cropped) 645 frame during shift?
BTW, I'm not surprised at the non-response from Hartblei Ukraine. They were never very communicative, and less so after the German deal.
01-13-2013, 08:20 AM   #5
No vignetting at all. The second image was shifted 10mm upwards and I found the image fine up to 7 to 8mm shift.
This conversion was done in professional machine shop in Korea. The place is much like Zoerk. in Germany but not German quality.
40mm, camera, custom, hartblei, image, lens, medium format, quality, shift
home made tilt and shift for 645D oxonet2000 Pentax Medium Format 24 04-26-2013 03:24 AM
645D and Novoflex tilt/shift bellows Femtometer Pentax Medium Format 3 04-25-2012 07:07 AM
Titl shift lens for the 645D erick Pentax Medium Format 61 11-21-2011 08:52 AM
Tilt/shift for 645D surfotog Pentax Medium Format 2 06-17-2011 04:22 PM
645D - Shift Lens lats Pentax SLR Lens Discussion 2 12-15-2010 03:11 PM
All times are GMT -7. The time now is 12:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
