02-10-2013, 02:31 PM   #1
klaus123's Avatar
67: Defect-open shutter....sometimes
Hello
Sometimes I observed following defect:
- Pre-release of the mirrow
- Release of the shutter with 1/2 or 1/4 second
- Shutter stays open - no reaction on any activity (reset button etc.) - taking of the lens shows the film
- Shutter only closed after battery removal
Sometimes everithing works fine, sometimes not
Defect only after pre-release of the mirrow
Does anybody have similar experiences or an idea?
02-10-2013, 06:46 PM   #2
Giveaway winner!
MysteryOnion's Avatar
How about a few questions?
So, how many rolls of film has gone through it since it was last serviced?
How many seasons since its last been serviced?
Any times in the rain or in high humidity?
Any drops, bumps, thumps?
Have you been using long exposures a lot?
02-11-2013, 12:47 AM   #3
klaus123's Avatar
Last service (due too defect shutter brake) is app. 6 Rolls and 4 Months away.
02-11-2013, 05:52 AM   #4
Check this thread
Check here: https://www.pentaxforums.com/forums/pentax-medium-format-645-6x7-645d/183346-...lp-me-out.html
Sterling
02-11-2013, 07:53 AM   #5
Giveaway winner!
The shutter brake is a critical adjustment... have you noticed any over exposures?
Yes... sbjornda... the contact switches are possible.
Intermittent operation could mean extreme cold as well.
If you are looking to venture inside the camera body, keep in mind that the side plate to the mirror cage is secured underneath the covering as well as the inside of the prism dock area.
camera, defect, medium format, mirrow, pre-release, shutter
Shutter only fires sometimes with manual lens - sears 50mm f1.7 jptruesdale Troubleshooting and Beginner Help 4 10-11-2011 08:16 AM
When you open a Film door it resets the shutter count down to 0 right? Abstract Pentax Film SLR Discussion 19 04-30-2011 12:18 PM
Help! Pentax 67 blank frames/shutter issue kkado Pentax Medium Format 6 03-02-2011 08:04 PM
P30T, shutter will not reliably stay open on bulb with cable shutter control. skid2964 Pentax Film SLR Discussion 6 06-09-2008 08:04 AM
Open Shutter ruemiser Pentax DSLR Discussion 17 12-18-2007 04:29 PM
All times are GMT -7. The time now is 10:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
