Originally posted by gordon_l34 Hi,
I have just spoken to the gentleman who has the outfit for sale.
The camera is an 6x7 with MLU, and S/N 4125660. It is fitted with a Meter, S/N 575699.
The 45mm f4 is an SMC Pentax 6x7
The 55mm f4 is an SMC Pentax 6x7
The 105mm f2.4 is an SMC Pentax 67
The 135mm f4 is an Super-Multi-Coated Macro Takumar 6x7
The 150mm f2.8 is an Super-Multi-Coated Takumar 6x7
He does not know what type of meter it is fitted with, however.
Regards.
Here's some detective work for you: ask him to look — you are, after all, considering purchase, no different to peaking under the bonnet of the car you fancy: if the "big box on the top" (prism) has a very small on/off toggle switch on the top right rear side and a bulky "bridge" to the shutter speed dial on the left, then it is a TTL prism meter (see photo; sorry about the focus; I've lost my glasses and typing this with very large text!!)
On the other hand, if it is just a prism with no bridge to the shutter speed dial, the it is a
manual camera and you will need a separate light meter for exposures. But you can always buy a TTL prism meter off FleaBay (around AUD$370).
What condition is all this kit in? Any mention of it?
Now, I would inspect the 6x7 version 45 and 55mm lenses carefully; these are the older models, not quite Takumar vintage.The 135 and 150mm old Takumar lenses might be too much too soon; if you have the option to whittle down the list, be sensible because that kit is
bloody heavy with all those lenses (you'll find out immediately the 67 / 6x7 itself is not a lightweight babe...). The 105mm would probably round out your kit perfectly as an introduction until you get a feel for telephoto lenses (my own kit is 45mm, 55mm and 165mm LS and all that is
quite enough to haul around in the bush in a day!). The mirror-lock up is a
must have for that reason (telephoto lenses and to negate mirror/shutter slap at low speeds).
• Photo: TTL prism meter
