Originally posted by elsdad I wear glasses and after I put the new cap on I started thinking about which eye workes best.
You can find out which of your eyes is the dominant one (if any) by a simple test.
Use your index finger to point at a small object with a straight, extended arm. Make sure the object is at least 3m away. Now close only one of your eyes (without moving the finger).
If you have a dominant eye, your finger will still appear to point to the object (or at least close to it).
With the other eye, it will appear that the finger is not aiming at the object (or at least farther away than with the other eye).
Originally posted by Bramela Eye specialist told me everybody has one dominant eye, be it L or R.
That's apparently not true.
Some people use both eyes to an equal extent. If they perform the test the finger will "jump" away from the object in equal amounts.
