05-04-2013, 06:36 PM   #16
Douglas_of_Sweden's Avatar
Praktica sold mirror lenses that covered 6x6 that could be had in a couple of different mounts including their pentacon six. But I've only seen one of them in real life. They would probable be adaptable to pentax 67, 645 or similar.
05-04-2013, 10:16 PM   #17
600mm Arsenal 3M 3B for P6 on eBay
here - Arsenal Pentacon Six 8 600 mm 3M 3B Mirror Lens | eBay
and here - Arsenal 3M 3B 8 600 Vintage Russian 600mm Lens | eBay
05-05-2013, 07:48 AM   #18
thanks for the hint with the ukrainian "3M-3B Mirror" Lens.
It must be very rare:
QuoteOriginally posted by sph_ebay_dealer:
Arsenal Pentacon Six 8/600 mm 3M-3B Mirror Lens Serial #96001 very rare lens, made only 200-300 Piece
and
QuoteOriginally posted by pentaconsix.com:
3M-3B
f/8 / 600 mm
No stop-down (Mirror lens)
7.5 deg (14)
6.0 m
Front: M 98 1 (15) Rear: M 52 0.75
115 195mm
2200gr
14) Something must be wrong here! If the 500mm APO does have a focal length of 500mm and the 3M - 3B does have a focal length of 600mm, the angle of view will not be the same. This is based on published data. Actual tests show that the angle of view with the 3M-3B is substantially less than with the Arsat APO MC and Pentacon 500mm lenses. Details of these tests can be seen here.
(15) This lens is extremely rare, and it seems that there were only extremely small production runs of it, often separated by gaps of many years. Between the different production runs, various cosmetic changes were introduced. There may also have been other changes, for instance, to filter sizes.
Russian & Ukrainian lenses for the Kiev 60
05-09-2013, 05:13 PM   #19
Hi - someone from this forum sent me a PM related to these lenses and adapters. Please resend - I accidentally deleted it and I am unable to retrieve it.
The message was about adapters for these mirror lenses with P6 mount. There used to be three or four different companies out there that made these adapters, but only one (DVD Technik) is still offering them on ebay. Unfortunately, all of these adapters are somewhat different. There was a cheaper brand that would frequently fall apart after some years of use. DVD Technik adapters are fairly robust, but slightly too thick for the P645D mount. They would fit well on the 645, n, and nii, but are very tight on the 645D. Perhaps removing some of the paint with a solvent would help or polishing them with a Dremel tool. My DVD Technik adapters fit on the 645D, but are a little bit tight as well, but not too bad. Perhaps sample variation. As I mentioned on several occasions, the 645D works very nicely with the Carl Zeiss Jena 1000mm mirror, but there is only one adapter that fits both the Jena and the 645D, and that one is no longer made ... I think the Zoerk adapter might fit as well as I remember that it wasn't too tight.
All of these P6/Kiev mount mirror lenses are fairly uncommon, to answer one of the previous remarks, perhaps production cycles of 50 or so. I like my 500mm/5.6 as it is fairly compact, lightweight, and a good fit together with shorter focal lengths in a bag. Images are fairly sharp as long as the lens is well supported.
camera, cat, lenses, medium format
P645N Large Eye Cup Problem asahijock Pentax Medium Format 21 10-24-2018 09:51 PM
Wanted - Acquired: Two 220 Inserts w/ cases for P645N ASA32 Sold Items 1 04-23-2013 12:57 PM
P645n shutter release button/contacts stuck pe645user Pentax Medium Format 2 09-12-2010 07:45 AM
Rear lens cap for the smaller Pentax lenses and for the DA * Russell-Evans Pentax SLR Lens Discussion 12 11-24-2009 03:29 PM
How reliable is the P645N, been thinking to buy a 2nd hand or a new old stock nevin Pentax Medium Format 7 09-16-2009 01:43 PM
All times are GMT -7. The time now is 03:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
