The fact the sensor is build out of two sensors is true. It is the same for all sensors bigger than 24x36mm - and if the sensor is bigger than 36x48mm, it is built of more than 2 sensors. The reason is: The steppers used in the production do not offer more than 24x36mm. As many things can go wrong during builing one sensor out of two, prices for sensors bigger than 24x36mm are much higher than 24x36mm.
The question is now: Where does the company set the limit of "something went wrong, let's throw this sensor away". Brighten a RAW picture by 4 stops in post processing is certainly extreme and leading to noise, banding and many other bad things with most of the digital cameras, expect a few cameras, like the Nikon D600, D800. A sensor showing bad behavior in this situation is not broken and will most likely not be replaced. On the other hand, making a picture brighter by 1 or 1.5 stops is very common, if this is sufficient to cause a problem, they will have to fix it.
