09-19-2013, 05:12 PM   #1
645 lenses, what does the * stand for?
And which 300 mm fixed lens is the sharpest. I am shooting with the 645n. Thanks
09-19-2013, 05:26 PM   #2
The star means it's a premium lens, sort of like canons L series. On film any of the 645 lenses will probably be good enough.
09-19-2013, 05:26 PM   #3
hks_kansei's Avatar
From memory, the * or "star" denotes that the lens was one of the higher end lenses.
Usually better optics, wider aperture, etc.
They still use the same system with the DA* lenses vs just a DA lens.
09-20-2013, 07:55 AM   #4
I could buy a used 300 FA* F4 for about $250 -300 more than I could pay for a 300 A F4. Ignoring the dollar factor does anyone have an idea of which would be the better lens for film? My crude understanding was that this A lens is very highly regarded and is a very sharp lens, but that the * line of lenses might even be better, even though in this case it is the FA * 300. If both are in good shape would I even be able to see a difference. Both are F4, IF lenses, and I could spring for the extra $$ if the FA* is sharper than the regular A 300 F4 lens. Thanks Norm
09-21-2013, 12:16 PM   #5
The 645 A 4/300mm is itself a * lens, and from my own experience, a very sharp lens too. Better than the K 4/300mm for example.
The downside is: it has no tripod mount, which I think the FA has. That is a considerable advantage.
The FA 5.6/300mm may be slightly less sharp, but is far lighter, so do consider that one too.
09-22-2013, 07:12 AM   #6
Buffy's Avatar
Re: 645 lenses, what does the * stand for?
While I have never tried the 300mm f/5.6, I do have the 300mm f/4 and I can tell you it is excellent and one of my 3 favorite lenses for the 645. (The other two favorites are the 35mm f/3.5 and the 120mm f/4 macro.)
09-22-2013, 09:23 AM   #7
I have both and would miss the 300mmF5.6. It's much lighter, has a shorter minimum focus distance. If I expect good light or have to walk miles the F5.6 is what i take.
-Linus-
09-22-2013, 11:54 AM   #8
I have the 300/4 SMC-A* and ist is a good lens on the 645D. Completely open a bit soft and low contrast, but this changes suddenly when going to f/5.6
The only drawback I see it is not really working well with the 1.4x converter. Pictures don't almost provide any additional details compared to a crop. Off course, again using the 645D. The converter works very well with the 200/4 SMC-A on the same camera for landscape (at f/11 to f/16), so I use the combination of 200/4 and 1.4x converter as light telephoto lens.
09-22-2013, 04:23 PM   #9
tootall's Avatar
I have the A* 300 f4 and use it the 645D, K5 and the Q all with very sharp results.
Before I bought it, I asked the same question and looked at the FA version, in the end I felt I wasn't loosing any sharpness by going the cheaper A*.
camera, medium format
What The #%@l! - Flier Forced To Stand joe.penn General Talk 22 11-29-2011 03:17 PM
how well does shake reduction work for video? and how does mJpeg stand up to grading clark Video and Pentax HDSLRs 23 06-22-2010 09:35 PM
What Does The Asterisk Stand For? I.g. Pentax A* 200mm f. 2.8 brandontowey Pentax SLR Lens Discussion 12 02-26-2009 01:43 PM
What Does The SD Stand When Referring To A Lense? brandontowey Pentax SLR Lens Discussion 5 02-23-2009 07:02 AM
What does the acronym DA actually stand for ? Confused Pentax DSLR Discussion 10 07-06-2007 05:43 AM
All times are GMT -7. The time now is 11:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
