10-04-2013, 11:44 AM   #1
Pentax 67II time exposure button question
Hi guys, I'm reading the manual now and I don't get the time exposure button.
Let's say I'm doing a 5 min exposure. I set the aperture and slide the time exposure button out and wind the film and depress the shutter release button using a cable release...and wait 5 min...
then at 5:00, Do I have to push the time exposure button back to close the shutter? I'm doing a test without the lens and the shutter remain open even thought the cable release was released...I thought not touching the camera during the exposure is #1 rule for long exposure photography.
Thanks,
10-04-2013, 12:10 PM   #2
Try without cable release, since in the gray box there is written "The shutter will not close until the time set with the dial lapses, regardless of the shutter dial position and the position of the time exposure set lever.". So I think that maybe there is a bad comunication between cable and camera (mechanical or electrical, depending on what type of cable you have).
10-04-2013, 12:14 PM   #3
QuoteOriginally posted by gabro822 Quote
I tired without the cable release and it's same. The shutter remains open unless I push back the time exposure button by hand which will cause a shaky problem.
10-04-2013, 12:49 PM   #4
If the exposure is long enough, pushing the PS.TIME slide back in to finish the shot won't effect the exposure.
If you're worried, use the 'black bag' method, ie cover the lens using a black bag, then close the shutter.
10-04-2013, 12:51 PM   #5
If you are doing a 5 minute exposure, any camera shake caused by sliding the time switch will be in the last 1 second of exposure. This won't show up on the film.
10-04-2013, 01:17 PM   #6
QuoteOriginally posted by rob1234 Quote
I see. I will do the black bag trick for shorter ones. Thanks,
10-04-2013, 03:08 PM   #7
gofour3's Avatar
The 67II Time Exposure Mode is designed to save battery life during long exposures.
You can always use the traditional way and set your shutter speed to “B” bulb. Then hold open the shutter manually using a cable release for as long as you wish.
Phil.
10-10-2013, 11:20 PM   #8
Exactly what Phil said. But you should still understand and learn the feature for a time when you really do need it.
10-11-2013, 07:17 AM   #9
revdocjim's Avatar
I would think the only time you really need to use the time exposure mode instead of the bulb setting is if your exposure is really long (more than a minute) or if you are doing a whole bunch of long exposures. It was designed especially for astro-photography.
button, cable, camera, exposure, medium format, release, shutter, time
Time Exposure gordon_l34 Troubleshooting and Beginner Help 8 01-03-2013 04:20 AM
Broken shutter button exposure indicator on Super Program PPPPPP42 Film SLRs and Compact Film Cameras 19 03-31-2012 02:50 PM
Long exposure time Ryalux Pentax K-r 10 01-28-2012 03:08 AM
Night Time Long Exposure Question MarieDJ Film SLRs and Compact Film Cameras 9 09-13-2011 07:21 AM
green button to set exposure slow2focus Troubleshooting and Beginner Help 3 12-14-2009 08:25 PM
All times are GMT -7. The time now is 09:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
