Originally posted by revdocjim As mentioned above, there is no chain on the 67ii so no worries there. And with the 6x7 and 67, your first statement is correct. Always take the lens off before switching finders, particularly if one of them is the AE finder. But the second part seems wrong. If no finder is mounted you can mount and dismount lenses as much as you want, no problem. Just make sure that if you are switching finders, you must remove the lens first and switch finders with no lens attached to the camera.
Thank´s
In the Operating Manual, TTL Pentaprism Finder For Asahi Pentax 6x7 the instructions for (safely!) mounting the finder and lens are as follows:
"Mounting
1. After removing the standard pentaprism or other viewing unit, remove the lens from the camera body. This is necessary to properly position the diafragm coupling slide on the viewfinder frame for solid connection with the diafragm coupling pin on the Pentaprism Finder.
2. Attach the shutter speed dial adaptor (supplied with Pentaprism Finder) onto the shutter dial on the camera body.
3. Mount the Pentaprism Finder securely on the camera body, making sure that the lock pins »click«.
4. Turn the shutter dial on the Finder until the coupling pin drops into the slot of the shutter dial on the camera body.
When the pin drops, you will hear a distict »click«.
5. Turn the shutter dial adaptor. Make sure that both shutter dials turn simultaneously.
6. Re-mount the lens on the camera body.
Function
*The Pentaprism Finder can safely be removed from the camera body with the lens on."
(..use alternative viewing unit and then return to Mounting, step 1. etc. to mount the TTL Pentaprism Finder again.)
The last line is confusing, is it not ...
The caution is for the TTL Pentaprism Finder only.
